Question about Canon Office Equipment & Supplies
Canon ip1800 series paper jam error but there is no paper jam. How do I get the back off this printer. very frustrating!
  • 29 Answers
SOURCE: Canon PIXMA MP160 showing paper jam, but none
don't know if it's the same problem i had but its maybe worth a try. My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Yesterday someone replied to my problem, i tried it this morning and its fixed 1st time.
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving PUSH it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 02, 2008
SOURCE: 'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Posted on Mar 04, 2008
TIPS72
  • 369 Answers
SOURCE: Canon MP610 - Paper jam error message
PLEASE REMOVE THE POWER CABLE AND REINSERT IT IT SHOUL BE OK AND IF STILL PERSIST JUST RESTART THE PC IF STILL RESIST PLEASE LET SOME TECHNICIAN TO CHECK FOR THE SENSOR FOR THE PAPER JAM ...
GOOD LUCK
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: canon ip1880 continous paper jam error on screen
first you turn off your p.
Posted on Mar 26, 2009
  • 13433 Answers
SOURCE: Canon MP140 paper jam error with no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
Printer is jamming when paper is trying to feed, on right side
There are two possible problems:
1. A part that holds the feed roller which normally breaks in the Canon iP1800 series
2. The spring that guides one of the gears at the rear of the cartridge parking position is loose.
This is the usual problem I had with my canon printers, I had 80 printers in the past two years.
If you can dare to dis-assemble your printer, I might be able to guide you through it.
Jul 31, 2010 | Canon PIXMA iP1800 Printer
I got an error with my canon ip1900 it says "paper jammed" i press Resume but nothings happen it's just repeating the error "paper jammed" what i need to do?
You need to open the printer and remove any piece of paper no matter how small. This can be causeed by even a small sliver of paper or even paper dust. It can also be the paper sensor but thats very uncommon.
Take the paper out fan and restack it. Then open up the printer and clean it as best you can. Put everything back in and close it up and you should be printing.
Mar 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
What is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
Apr 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
The ink absorber is full... for the canon PIXMA iP1800
My printer is not printing for feed paper. It tells me that it has a paper jam, but there is no paper in the printer. Please advise
Dec 05, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
PRINTING PROBLEM WITH CANON IP1880
Shut the printer off. Than unplug it's power. Than unplug the USB/data cable. Wait about ten minutes. Allowing printer to reset it's self. Go to pg. 37 of your manual & follow instrctions for cleaning. Connect the power cable, the usb/data cable & turn on the printer. Test printer for error paper jam (light/display message). Canon's web site for drivers, updates, software & guides. PIXMA IP1880 is the iP1800 series.
When web sites loades you must choose your operating system from the drop-down menue.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=14991
Problem not corrected? Uninstall printer software. Re-start PC. Re-install software. Re-start PC & re-test.
Hopefully you will not need to uninstall & reinstall.
Feb 11, 2008 | Office Equipment & Supplies
783 people viewed this question
old marine
old marine
