Question about Mad Dog Multimedia MD20XTLE External DVD Drive DVD Drive
My laptop keeps recognizing it as just a cd drive. I need a driver
  • Mad Dog Mult... Master
  • 27,725 Answers
make sure all leads that are attached to your cd/dvd floppy drives have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Apr 07, 2011
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Cd dvd drive is not recognized in my computer, how can I get it recognized?
Having done all of that, if the drive D is not there, replace the drive as it is likely to be faulty.
Jan 18, 2014 | Toshiba Satellite A215-S7422 Notebook
Download cd driver for a gateway nv54 laptop
Your operating system shouldn't need a new driver for that. CD drives are recognized configured automatically. You can try cleaning the laser lens on the CD Drive with a CD/DVD laser lens cleaning kit. If that doesn't work then you'll need to replace the drive.
Jun 23, 2012 | Computers & Internet
I have Dell6400 inspiron .My Cd drive is not recognizing cd. I tried to install turbotax cd but does not recognize. Stating go to control panel and configure?
does it recognize any other cd? if not you might have to go to device manager, cd drive right click advance properties and select pio mode.
Mar 15, 2011 | Dell Inspiron 6400 Notebook
CD Driver not being recognized, went into device manager and under device status it says, "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)
this is a tough one. I found this at acer:Optical Drive
8X DVD-Super Multi double-layer drive or DVD/CD-RW Combo
(varies by model)
The bad news is the part where it says varies by model. You will need the exact model of the drive to get the proper driver for it. My advice is to take it to an Acer shop and ask them to identify the cd drive for you.
May 06, 2010 | Acer Aspire 3680 Laptop
Slimtype DVD a Ds8a1p Ata Device Driver NOT FOUND IN MY NOTE BOOK AND NOT HAVING DRIVER IN CD
Go into your BIOS and see if the drive is recognized in there. If its not, then you'll need to turn off the laptop. Take out the drive from the system and then put the drive back into the system. Now go back into the BIOS and see if its recognized in there. If it is still not recognized then the drive is bad and would need to be replaced.
If the drive is recognized then go into windows into the device manager and see if the drive is there. If its not recognized properly then that means you might either have spyware or a virus on the computer. You can also try replacing the drive as well to make sure its not a drive problem.
Apr 19, 2010 | HP Computers & Internet
A required cd dvd drive device driver is missing
i think you need a new windows cd that has no errors, your cd might have some files missing
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
HP Pavillion dv9000 cd/dvd driver has problems
I would recomend replacing the cd drive, a driver update would not resolve this issue. It sounds like hardware to me. I would search on ebay and get a used or like new one and replace it yourself if you know how to replace it. The HP website will show you how to do it yourself.
Please post update
Feb 19, 2009 | HP Pavilion dv9000z Notebook
My laptop cannot recognize my external cd rom
Need to go to the hard drive maker website and look for a driver and install it to your computer search for the model # on the website of the hard drive company
Jan 31, 2009 | Toshiba (PX1052E-1NMD) External 24x CD-ROM...
Mad Dog Multimedia MD20XTLE External DVD Drive DVD Drive Logo
63 people viewed this question
Top Mad Dog Multimedia Computers & Internet Experts
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
Are you a Mad Dog Multimedia Computer and Internet Expert? Answer questions, earn points and help others
