Question about Maytag MBB1954G Bottom Freezer Refrigerator
Not cooling properly.unplugged overnight then plugged in for an one and a half hour, compresor not starting
  • Maytag Master
  • 8,220 Answers
Your relay might be shot. The relay slides on the compressor pins. What it does is allow all the copper windings inside to power up the motor. When the motor gets going it also drops out half the windings in the motor. Gives the motor a little more power to get going. So what happens? Over time the relay simply falls apart from use.not cooling properly.unplugged overnight then - themobilian_2142.jpg
Maytag bottom mount ice box service manual
Posted on Apr 07, 2011
Danny DPA120B1WB portable Air conditioner 12,000 Btu will not produce cool air. The fan will start but no cool air. I tried to reset, restart, and clean filters.
This may sound foolish but it works turn the unplugged air conditioner upside down and leave it that way for about hour and a half , then turn it back over after the hour and a half let sit for half hour plug it in and it should blow cold air , by turning it upside down it allows the oil in compresser to flow
Jul 23, 2016 | Danby Heating & Cooling
Brand new mini fridge was on it's side before being set up. Plugged in too soon. Now it won't start cooling. Are we out of luck?
It could be that liquid coolant got into the low-pressure part of the cooling system when it was on its side, and is preventing the expansion valve from doing its job converting high-pressure liquid coolant to gas. My recommendation is to unplug it, wait the 24 hours, and plug it back in. Excess fluid should have drained to the bottom of the cooling system by then, and normal cooling can begin.
Dec 19, 2013 | Black & Decker Food Processors
Condensing has a humm but will not start?
compresor is probally hot also. Shut down unit and if you can put a fan on the compressor. While its cooling down try and remove and dirt, from the condensor coils. They are right there with your compressor. After an hour plug back in and see if it starts. let me know, hope this helps.
Jul 31, 2011 | Refrigerators
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
Used Kenmore freezer won't get cold enough
If it is running but not cooling enough the problem is in the sealed system.
If you started it up just after hauling it home it may have be moved around enough to get oil in the systems smaller tubing causing problems. Unplug the unit for 24 hours and let it sit. Try it again for 24 hours and see if it cools.
If not this means either there is a refrigerant (freon) leak in the system or a restriction causing the refrigerant to not flow properly.
Either one are an expensive repair. and will require a professional to look at.
May 09, 2010 | Kenmore 5 cu. ft. / 142 liter Chest...
Whirlpool stopped blowing cool air. Unplugged
It sounds as if your defrost timer has failed. Unplugging the unit over night allowed the unit to defrost. If unplugging it overnight or by using a stnd fan blowing into the freezer section for 90 minutes results in the fan blowing cold air then your unit is not defrosting. Most often the defrost timer is the problem. However there could be other defrost circuit like the thermostat or the defrost element. In order to provide you with the correct solution and defrost timer location you should privde your model number for further instructions.
Jan 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Does not cool and compressor relay keeps intermittently buzzing every 1 to 2 minutes. Condenser coils are cleaned and when you check across the overload protector pins there is no continuity.
When there's not continuity across the overload is because the compresor overheated , it could be the relay or the compressor that is burned out or stuck .I would let the compresor coold down for a few hours (unplugging the unit) and replace the relay (no more than $20) and if still having problems the compressor needs to be replaced.
Aug 23, 2009 | Amana Freezers
GE monogram fridge: Poor Cooling after cleaning
Temporary solution.
Open the top hook. leave it open overnight.
Check in the morning if the temperatures comes back to normal. It works for me!
Jun 06, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Maytag MBB1954G Bottom Freezer Refrigerator Logo
73 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
