Question about Nitro PDF Software PrimoPDF
During the installation of Nitro PDF pro I have the error 2753
    President:
  • 2,340 Answers
For OS -> Vista or Win 7, try these steps.
Start ' CMD ' Right Click and Run as administrator ' regsvr32 vbscript.dll
and, reinstall your Nitro PDF pro Installer.
Windows XP Users -> Read this link @ http://www.ehow.com/how_5047270_fix-internal-error.html
If you still get the error 2753, try using another Nitro PDF pro installer. Corrupted files from the installers can also cause these errors.
Hope it helps.
Posted on Apr 07, 2011
Soda pdf software is not uninstalled after 15 days (free) and shows error no. 2753
go to control panel then go to programs uninstall programs then dobble click on it then scroll down to the desierd program and unninstall
Aug 16, 2011 | LULU Software Soda PDF Max
I get a Runtime error message constantly then a crash. can't open my pdf files.Using A Reader X
If your only intention is to open .pdf files and not Adobe Reader X problem, then there is a easy solution to open the .pdf files. You can use Foxit Reader or Nitro PDF Viewer as a PDF decoding software, These can give you the same results ( in some cases, more than you want!!!) with respect to Adobe Reader X. Amongst these PDF viewer, I recommend you to use Foxit Reader, as this is very much lightweight with respect to Adobe Reader (About 14 times smaller) and handy.
You can download these PDF readers by clicking over the following links:
And if you still want to use Adobe Reader X, then you should uninstall it and try re-installing it again, because it may be the problem of file corruption or improper installation of Adobe Reader.
Hope this helps,
Regards,
Mrityunjay
Apr 22, 2011 | Adobe Computers & Internet
Sage Instant Accounts error Message Coming up during installation, Internal error 2753 eirregistration.dll
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Feb 01, 2010 | Sage Instant Accounts 8.0 (013604ug)
I'm trying to reinstall Novabackup version 10 after reinstalling windows XP. I almost immediately get the message announcing an unexpected error and citing error 2753. How can I resolve this?
hi,
Error 2753 is caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
How to Repair Error Code 2753
RegCure is a Microsoft Windows tool designed to repair code 2753 problems & errors.
Dec 01, 2009 | Computers & Internet
Error 2753 HP3050
If it is related to the infamous Fatal Error, MSI.dot4msi, code 2753 of HP installations, then it is not a compatibility issue, but an installation problem.
The HP un-install does not clean its previous installations well, causing some of the dll-s to be locked by Windows, thus disabling install of the new software.
What you need to do is manually delete any trace for HP previous installs from your PC.
Search for HPz*.*, HPw*.*, HPq*.* files, and delete them. Those files that you cannot delete - rename them and delete in safe mode.
Also, search the registry for any HPAIO entries - delete all of them.
Then, reset your PC, and install the new software.
It worked for me (and this is the only thing that worked...)
Good luck
Jun 09, 2009 | HP LaserJet 3055 All-In-One Printer
Can't install drivers for Vista Home Premium
I would suggest you to go for restoring the system to a good known configuration.
Do a System Restore..
Otherwise more info on such issues can be get on Microsoft Article:
http://support.microsoft.com/kb/908267
Jan 07, 2009 | HP Photosmart C3180 All-In-One InkJet...
Error 2753 HP3055
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Jun 26, 2008 | HP LaserJet 3055 All-In-One Printer
Error Code 2753
be sure to completely remove any programs having to do with sprint smartview reboot computer and then plug the air card in the computer and run the setup from the pop up window that states new device found reinstall the smartview connection manager through the preinstalled drivers located in the device itself then after installation is complete reboot and then connect issue is fixed
Jan 26, 2008 | Computers & Internet
Computers & Internet Logo
1,144 people viewed this question
Top Nitro PDF Software Computers & Internet Experts
David Payne
David Payne
Are you a Nitro PDF Software Computer and Internet Expert? Answer questions, earn points and help others
