Question about Acer Aspire 4520-5582 Notebook
My mouse pad is not responding - Acer Aspire 4520-5582 Notebook
Toshiba touchpad doesnt respond after 2 minutes
This issue could be a few things. 1. Make sure your driver for the mouse and keyboard are updated. 2. The mouse pad may be going bad. 3. There may be an issue with the motherboard. I would recommend checking your driver first. Then replace the mouse pad. You can also pick up a wireless mouse and plug the usb that comes with it into a usb port if you are not comfortable tearing apart your laptop.
Jan 11, 2014 | Toshiba Computers & Internet
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Laptop pad not responding at all
Make sure that the drivers are installed for the pad. Also check and make sure the pad is turned on in the BIOS. You also need to make sure you have the software installed that allows you to toggle between the two.
Apr 27, 2010 | Sony VAIO VGN-FZ240E/B Laptop
Why wont my mouse pad respond normally?
if you're using windows vista, it's a known issue. configure your power settings so that your computer will not sleep when you close the laptop lid.
Mar 14, 2010 | HP G70-460US Notebook
New cordless mouse slow to respond to "click": cannot control or direct movement: jerky, sporadic. Is this because I do not use a mouse pad?
mouse pad would help but you may have a virus so go to windows help and support and download the windows defender and run it, there have been a lot of bugs affecting mice lately however do try to use something that has a surface on it that would make the mouse work better if it does work better then buy a mouse pad next if it's still slow you can go to control panel and sped up the mouse and also into tools Internet connections and change the mouse properties there.
Feb 05, 2010 | Logitech Cordless Mouse
Computer does not respond to mouse. Move from pad
Do you mean you might used it on you lap rather than the desk and have changed the angle of the mouse? It will be the lazer, (if changing the angle of the mouse works). Disruptions occur with the lazer, hey they don't wear like a ball mouse does. You can have it repaired, just have to decide if it is cheaper or easier to just replace it. (Tip, don't leave it in direct sunlight when you are away from the computer. It shortens the life of a lazer mouse).
Nov 25, 2009 | Logitech Cordless Mouse
Mouse arrow no respond & touch pad oso cannot respond
download driver max, it's free and will scan your pc for all hardware and update all drivers, but allow you to choose what and when so you can fix any bad drivers.
Aug 24, 2009 | Daewoo DVRS05 DVD Recorder/VCR
The mouse pad right and left clicks do not always respond
nope! the whole board matrix needs replacing. use a usb mouse
Aug 19, 2009 | Computers & Internet
Left mouse pad doesn't respond, or sticking
It's probably a hardware defect ,you can take it to an authorised Dell service center and they can make you a quote ,in the meantime you can use a USB mouse.
Apr 23, 2009 | Dell INSPIRON 6000 CENTRINO...
Mouse not responding.
I take it that you have a wireless mouse.
Myself I prefer the ones that plug into the console.
Jun 18, 2017 | Micro Innovations KB1045LSR Keyboard
Acer Aspire 4520-5582 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
