Question about Vacuums
I have a broan v-16 central vacume i am looking for a owners manual
2 Suggested Answers
SOURCE: i am looking for a
Here's a link to the replacement belt.
http://www.appliancefactoryparts.com/search/partinfo.php?partsID=340707&modelsID=127219&typeName=vacuum cleaner
Posted on Dec 17, 2009
Central vac not sucking
Check for a plugged tube in the wall by listening to the motor when it's running. If it sounds like it's running too fast then there's an obstruction. If it sounds ok, then there's a disconnected tube somewhere in the system.
Sep 11, 2014 | Broan-NuTone CV353 Central Vacuum
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Jan 22, 2013 | Broan-NuTone CV350 Central Vacuum
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
Motor does not run. unit has power. circuit breaker has been reset. unit only "clicks" when vacuum hose unit is plugged in. possible brush problem ?
I have an old model 350 X. It does't run. It seems to be a problem with the coal brushes.
When I connect the 16 V points ,the relais clicks.
Once I sprayed the brushes with silicon oil, it runs a moment.
Mar 07, 2011 | Broan-NuTone CV350 Performance Bagged...
Beater brush won't spin when on carpet
You need to change the belt. When it does that it means it is worn. You can get replacement belts for it here:
Central Vacuum Belts
or here is
Broan Central Vacuum Belts
Nov 04, 2009 | Broan-NuTone CV350 Performance Bagged...
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
Base d on your description... you have a defective internal relay, value $25-30US . It sits under the lid beside the motor and has generally 4-6 low and hi voltage leads plugged into it. Sometimes this component and the transformer is replaced by a new circuit board.Tag all wires with # position remove and take to a vacuum pro shop. Original relay may look different from the new one.
Nov 01, 2009 | Broan-NuTone CV350 Central Vacuum
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
I have an old central vacuum that I don't have a manual for.
If it is a NuTone system you should have a filter and a BAG in the tank. just got to their site and look up your model number to see what you need.
Dec 16, 2008 | Broan-NuTone CV353 Central Vacuum
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
May 11, 2008 | Vacuums
Vacuums Logo
134 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
