Question about RTO AquaScape 4500 GPH Pump
My Aquascape 4500 pump immediately trips the GFI when I plug it into an outlet. This happens both when it is submerged and out of the water. The impeller is not obstructed.
    President:
  • RTO Master
  • 1,378 Answers
The seal has failed allowing water into the sealed motor unit and it is now shorted to ground...in other words the unit is shot and needs to be replaced.
John
Posted on Apr 07, 2011
Testimonial: "Honest and to the point. Thank You."
How to stop my whirlpool washer from tripping gfi
If it is tripping the GFI I would say you have created a short somewhere. Check that wire has not been braised, check the plug for signs of burning, check outlet for signs of burning. Plug another device into the outlet to see if something else trips the GFI. If something else trips it then you could have a bad GFI outlet. These are the basics to try first but could be a number of things beyond this.
Aug 31, 2012 | Whirlpool Washing Machines
Submerged pump trips gfi
Water is entering the pump due to a defective seal. Replace the pump or if poss rebuild it.
Jul 13, 2012 | Cars & Trucks
Our Magic Comfort plus is 4 years old and it keeps blowing the gfi instantly when I plug it in. I have had this problem occassionally in the past and it resolves after one or two gfi trips. Now if tripo...
The problem believe it or not your gfi is warn out. I am actually surprised it lasted as long as it has and surprised it worked at all. Espresso machines use a huge amount of power when turning on compared to maintaining power. When espresso machines first turn on the take a huge surge of power to start heating up the elements. Normally you want to put an espresso on a circuit /outlet that is directly to your breaker that is at least a 20 amp breaker. By code kitchens and bathrooms, where an outlet is near water, has to have a gfi outlet, this is for safety for something plugged in near water so it will trip if accident happens with appliance near water. The bad news there not to good with high demand power appliances such as espresso machines. Yes , you can replace the gfi circuit, by turning off main breaker, unscrew gfi from wall, pull out, and undo wires, and copy exactly when re-wiring the new one. Then turn on main breaker again. NOTE: you can buy a gfi all most any home improvement center, lowers, home depot, ace hardware etc.... Think of a gfi kind of like a advanced in line fuse, they do wear out. BUT AGAIN, my advice is plug it in a outlet that does not have gfi and is on a main breaker of at least 20 amps if you have that opportunity to do in your kitchen area. Hope this helps you, thank you....... MIKE
Jul 26, 2011 | Saeco Magic Comfort Plus Espresso Machine
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
Pump trips GFI when submerged
Check your power cable for any hole and damage, that might be the problem
if not
remove the 2 screw where the cable is connect on the pump, gently pull off the ruber from the cord and check if your 3 wire are wet ? and if any water can come out of the cable hole?
if yes you have to take most of the pump appart to make the stator and rotor get dry and also check for any black part on the stator, to make sure it not burn if you cant find any black spot on the part let it dry for a week and spray some air on the stator everyday and your problem will be fix,
At our big factory we use special oven to dry the part quicker
If you have no water that came out from the inside of the pump it has to be the power cable or your breaker the reason why the pump work fine when only the base is submerge is because the pump have less restriction (Water to push) so the engine work is very light compare when she is submerge and have to push so much water alll the way throught the hose.
I can help you if you need more info,
Aug 24, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Aquascape 4500 pump trips breaker when plugged in
water getting into pump.Thats what is triping it.
Jul 31, 2009 | RTO AquaScape 4500 GPH Pump
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
GFI for pump keeps tripping...
no you need to put 60amp breaker in house panel box
Jan 15, 2009 | Beckett Water Gardening Beckett Statuary...
RTO AquaScape 4500 GPH Pump Logo
290 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
