Question about Indesit Washing Machines
WIDL126 flashing light No3 extra rinse). Machine starts to fill with water then the drum spins twice (a little too fast I think), then drains and just stops and the door lock light flashes fast along with the extra rinse light. No3 light is listed as being fault F02 and F18 so I not sure what to do! any advice would be appreciated
    Genius:
  • Indesit Master
  • 1,474 Answers
If spin speed happening during what should be Wash speed then sounds like faulty speed control module/ could also be Tacho has fallen off end of motor;small round coil operated by a magnet which pulses a speed control circuit in the module/check also pump is okay and filter clean.Try resetting if you can,book will show you how to..Good luck
Posted on Apr 07, 2011
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Hi I have a auarius wma37 extra washing machine, It washes fine but just stops when it gets to rinse and spin. the drum drains to safe and the door will open. if I wait and change program to just rinse and...
Hi confused...It could be that your cold water inlet valve is faulty. Many machines will only rinse with cold water...No cold water...No rinse! Check that the machine actually is filling on the rinse setting. An inlet valve in not a big job....Nomess
Apr 05, 2010 | Washing Machines
When i put it on a wash cycle it starts then all of a sudden the power light flashes rapidly and the rinse hold light flashes steady
Fault code F02 meaning Motor jammed / tacho detached: check motor
& module connections.. on the motor plug check that a wire hasn't become dislodged or broken...
Dec 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Not spinning
I found my Classixx 1200 express with a flashing spin light, the water wasn't up in the drum, so I moved the selector to rinse, and pressed start, pump was noisy but worked, I could hear water going into the drain, thinking I'd got a blockage in thye pump, I drained machine using small hose and inspected the pump orifice at the front of the machine (towel handy to catch spillage.
No obvious blockage and the pump could be turned by hand, tried rinse again with water feed turned off, (otherwise it pumps for a while and then lets water in to rinse - which comes out the open pump housing!) I could see the pump impeller spinning but also sticking, its was also noisy.
Solution - new pump, according to my local spares shop, the pump is available as either motor & impeller (back half), or complete with black housing that the pipes fit to, to get the front cover off, and to remove the pump, you need a "star" screwdriver or key, and a pair of pliers to undo the hose clips - have a bowl ready to catch the water, and make sure the machine's unplugged before you start!
Jul 12, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Indesit WIL143S flashing lights
sounds like your power board is damaged. Did you get any washes out of it before it went wrong
Oct 08, 2007 | Washing Machines
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
381 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
