I have a 8g everyday USB flash drive. I get the message "Please insert store n go and run as privileged user. How do I do this?
  • 27,725 Answers
When you plug the usb drive in if you are unable to see the device follow these or you might have to be the computers administrator
click start control panel user accounts on the users tab,click the name of the computer administrator you can change the andministrator and password there
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Apr 07, 2011
How to run verbatim store & Go pendrive as privleged user?
Go the the Verbatim web site and search for your product
at the bottom of the screen is the support button
click it then go to downloads
and download the V-safe software again
then drag the downloaded file back onto your flash drive
then just click on it and just put in your password again....it should access the private zone then.
Sep 02, 2014 | Verbatim Electronics - Others
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I have an 8G Imation flash uSB. It has worked fine till recently but when I insert into port now it shows the files with hieroglyphic names and says it can't open them. Is there something I can do? Thanks...
i think you can defrag a usb drive, if it shows on your 'my computer' list of removable drives- you might try this- you can also run an anti-virus check on it, if you have an anti-virus prog. if that don't work, and the data is stored on your hd, then try re-formatting it.
if that don't work, toss it, and get a new usb flash drive!
good luck!
Oct 04, 2009 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Error "please insert data traveler and run as privileged user"
You have to logon using an account with administrive rights (like administrator) to be able to use the SecureTraveler software.
May 28, 2009 | Pantone ColorVision Spyder2 monitor...
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
Feb 07, 2008 | Computers & Internet
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
Dec 28, 2007 | Computers & Internet
Verbatim Thumb Drive problem
You may need to log on to the computer with administrative privileges. Ask your friend to log you into the Administrators account, then insert the drive.
Sep 02, 2007 | Verbatim CORPORATION 94933 USB 2.1GB...
Computers & Internet Logo
David Payne
David Payne
