Question about Samsung Freezers
I'm installing a samsung DA99-01457B and cannot see where i am to attach the water filter? there is a plastic connector under the left freezer doot but it does not seem to want to come apart to join into a filter? can you confirm these are the filter connectors?
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
WATER FILTER WILL NOT ENGAGE
Hi friend, I appreciate your post!
I see your question is labeled under Frigidaire refrigerator, FGHB2844LF, and you are having difficulty engaging the water filter. Based off that model you should be able to push on the face of the water filter and slide the old cartridge out. First, to install the new cartridge you would need to remove the caps off of it. Secondly, using the alignment guide slide the new filter into the housing until it stops against the snap-in connector. Thirdly, push firmly until you hear the click which indicates that your filter has been engaged. Lastly press a glass against the water dispenser to verify no leaks are present at the filter housing. Hope this helps. -Matt
Aug 02, 2014 | Frigidaire Gallery FGHB2844LF 27.8 cu. ft....
Need to replace the water inlet solenoid
The Samsung side by sides and french doors have split systems meaning both freezer and ref have evaps. Your water reservoir could be frozen. They have DC heater that is attached to reservoir so it does not freeze, this could be your problem. The other problem that I have run across is the water line in the door can be frozen. If it is the door, you can check by locating where it enters the door, because it will have a quick disconnect. Disconnect water line and grab a cup and place cup under diconnected line coming from cabinet on the door and press or have someone call for water on fountain. Let me know if that helps. Thanks Logan.
Apr 07, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I change the water filter for the refrigerator, Samaung RF323TE
Page 13 of the User Manual explains where and how to change the water filter RF323TE User Manual
Click link below for instructions
Where Is The Water Filter And How Do I Install It on my French Door or Side-By-Side Refrigerator?
Or click HERE If you have questions or trouble navigating the Samsung site please ask questions and I will try to assist you, Thanks Sea Breeze
Mar 31, 2013 | Samsung RF323TE 31.6 cu. ft. French Door...
Suddenly goes to harvest cycle, #1 green led is always on. overall it is not producing enough ice.
If the freeze cycle is too short, I would check to see if the plastic grid that is under the evap plates are missing any pieces. If so, then check the check valve to the left of the water pump. It is a white round plastic piece with a triangular attachment with 3 screws in it. Remove the screws with care as it is spring loaded. Check it for pieces of the broken grid as this will cause short freeze cycles.
Let me know if this does not solve and we will go a little deeper.
May 06, 2010 | Hoshizaki Commercial Freezer KM-500MAH
Installed new filter and machine will not make any ice
check the plastic manual water dump valve.MACHINE will not start ref mode until valve is set properly.
Jan 15, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Samsung water filter rs21 dcns
Hold down the "ice type" and "child lock" buttons (bottom button on the left and the right) together for about three seconds. The light will change back to green.
Aug 06, 2008 | Freezers
Poor tasting Ice
There could be a filter installed. The filter usually looks like a long tube about 6-10" long and about 1-3" round.
Try to located the water line. This will be either a copper or plastic tube about 1/4" diameter and will be going into your fridge from the back of the unit.
The filter could also be located at the point of where the water is being supplied from. Possibly under your sink or it could of been tapped into another line in the basement if you have one.
If you located a filter, you will be able to see if you would be able to remove it and replace it on your own. It usually takes a couple of wrenches, but MAKE SURE YOU SHUT THE WATER SUPPLY OFF FIRST before attempting to remove it or else you might have to go swimming. (Actually it's a small tube, so not a lot of water will come out, but you still need to shut off the water supply to the fridge. Then you can bring the old filter into your local hardware store and get a replacement.
I hope this helps.
Good luck.
Mac =)
Mar 20, 2008 | Freezers
Open Questions:
ca. 2010 GE fridge with Samsung ice maker. I have to hold the reset on the icemaker every few days to keep making ice or it quits. What's the fix? When it works, there's a loud popping every 3 seconds for about 2 minutes, then a few minutes later ice harvests into the bin. With my hand against the outside of the fridge next to the icemaker, I can literally feel each pop. I originally thought it was the ice release heater failing that caused cubes to pop loose hard, but I couldn't find anything wrong electronically when I took things apart and examined the board and connections in the icemaker. I may have missed something mechanically that's causing some part to flex and then suddenly give against the wall inside every 3 secs as the clock cycles through the beginning of a harvest? What might that be? But after reassembly it now has the added feature of harvesting a few times and then stopping altogether. We run flat out of ice if I forget to press and hold the reset button for 10 secs. every few days. Apparently the clock is cycling incompletely or something now. Could a cog be missing/broken/out of alignment in the clockworks, such that when it gets so far along it slips, but can be reset? How about the lift arm? Could it be out of position inside such that something it's connected to isn't properly repositioning when the arm drops back down? Or could all of this be related to a faulty control board elsewhere in the fridge?
Apr 19, 2017 | Samsung RS261MD 26 cu. ft. Side by Side...
Freezers Logo
354 people viewed this question
Top Samsung Freezers Experts
Jay Finke
Jay Finke
ray gallant
Michael Youngman
Michael Youngman
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
