Question about Saeco INCANTO DELUXE Espresso Machine
Red light remains on when I fit the brew group and machine won't operate
  • 2 more comments
  • jmcconvi Apr 07, 2011
    The email did not tell me how to fix the problem of not being able to refit the brew unit and the red light remaining on.
  • jmcconvi Apr 08, 2011
    The red light which stays on (not blinking) is the right lower one. The problem seems to be the brew group which won't fit back in properly and I think it needs resetting.
    I believe I have the brewer unit back in properly but the bottom right red light remains on and the machine won't operate.
    All of these seem to be all right - it is a continuous red light that remains on. I don't know about the sensors but the machine clicks into gear when turned on but the continuous red light stops it from operating.
  • 10,515 Answers
Kindly provide more details - Which red light is blinking - the left or the right one?
Thanks and Regards
taran_2005
Posted on Apr 07, 2011
  • 1 more comment
  • taran_2005
    taran_2005 Apr 08, 2011
    Thanks for your response!!
    Remove
    the dredge drawer. Open the door. On the left side and towards the back
    of the brew group, there is a single screw. Remove the screw. Grab the
    handle and pull carefully, but firmly with a quick force. The brew group
    should come out. There is a piece that remains in the machine. Slide the
    piece down and to the right and it will come off. Insert the piece into
    the hole on the backside of the brew group with the clip up. Tighten
    the screw and move brew group back into position. If your brew group did
    not come out please call your service center.
    To return the brew
    group to the centered position, you first need to drop the funnel. To do
    this, look on the opposite side of the brew group from the handle. At
    the top you will see an object that looks like a sharks fin. If you
    follow this piece down you will see 2 horizontal bars on the brew group
    body. Push your finger between these 2 bars and the funnel will drop.
    Now you can push the puck slide on the left side down and to the center.
    If you look down through the funnel you should see a piston. This
    should be centered in the funnel. If not just push the slide to the
    right until it does. Push the press button and you are now ready to
    reinsert the brew group in to the machine. First you must close the door
    and turn on the machine without having the brew group in. You will hear
    the motor turn on and when it stops completely, open the door and
    insert the brew group.
    This is to ensure that the brew group fits properly.However, if the problem still persists, then follow the steps mentioned below :-
    First turn the machine on.
    Then take out everything watertank, dreg draw and brewing unit and have the door opened to the brewing area.
    have them out for about 1 minute and then put it back together again.
    if this doesn't help please check if the machine respond to removing the dreg draw, bean lid.
    It will do it by making the constant red light flash instead.
    if they respond make sure that the watertank is filled to max.
    if that is the case it is the watertank sensor that is broken.
    Thanks and Regards
    taran_2005
  • taran_2005
    The red blink could be due to various reasons - Either
    you need to prime the pump, or the brew unit is not in correctly, the
    steam knob is not in the right position, the tray is missing.Even sometimes the sensor on these machines
    can be a little temperamental and so we often see them in for warranty repair because of this.The water level sensor is a white rectangular piece (1" x 1/2" x 1/4") located between the water tank and the grinder.
    Check out and let me know,so that we could proceed.
    Thanks and Regards
    taran_2005
  • taran_2005
    As you have inspected most of the reasons, sensor's could also cause the same issue.By passing the sensor is not that easy.Actually the sensor goes down
    when the water gets filled.If the sensor does not go down then no water
    gets detected.Sticking the sensor down is the option.But its not always
    successful.But in some cases cleaning the sensor in machine OFF
    condition.Then readjusting the sensor to its place then turning the
    machine On helps.but its not 100% possible.In some cases it helps.But
    still i advise you try to clean it and try to stick the sensor down
    manually and then check.
    In other cases it needs replacement.The Saeco parts are actually not
    very easily available online.So the Saeco service center has to be
    called to order the parts.But the Saeco service center is not very
    helpful and takes some time to provide the part.
    Thanks and Regards
    taran_2005
    Top Expert:
  • 74,666 Answers
Hello
The repair and service of your coffee machine is well described , if you go to the website I hereby includes. There is video demonstration, all about the troubleshooting of your device.
google in
seattlecoffeegear.com
Enter the site and click on repair center at the top of the window. OK.
Red light won't stop flashing. Parts are in place
Be sure all coffee grounds are cleaned from beneath the water tray and the grounds tray and the coffee brew group. We had the same problem but finally redid everything, including cleaning the coffee brew group under hot water, drying and replacing carefully until it clicked in place. The moving parts of brew group have to be in exactly the right place. Good luck!
May 12, 2012 | Saeco Spidem Villa
My brew group was stuck, followed instructions and got it out and motor turned to correct position. Put it back together and now nothing...green light comes on and thats it. No motor sound, that's i
Unfortunately I cannot locate your problem or duplicate it. The various units that turn on the red "stop" light are the grounds container, the drip tray and the brew group. When they are reinstalled the light goes out . So if your brew group was stuck and you had to force it out then you should check very carefully that there are no cracks or breaks on the back. Remember this, the brew group must "click" into place and lock so that it does not move in and out unless the "Press" button is depressed. It is possible that one of the above switches that signals the motor to start is stuck, even if the red light is out, and not allowing the motor to turn on. I don't see the reason why your brew group was stuck to begin with. How did that happen?
Nov 19, 2011 | Saeco Vienna De Luxe Espresso Machine
Saeco Royal Digital Plus - I cannot insert the brew unit into the machine
Hi Remove the dredge drawer. Open the right side door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door, insert the dredge drawer and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door, pull out the dredge drawer and insert the brew group. Done PS: If it still won't go in you might have a broken brew drive. The gear in the back of the machine where the brew unit goes has 2 large teeth. They should be in the 10:00 and 12:00 position. If they are in the 3:00 and 5:00 or that side you have a broken drive and the gears need to be replaced.
Jul 06, 2011 | Saeco Royal Digital Plus Coffee...
Red light flashing brew group stuck in machine
Hi
Remove the dredge drawer. Open the door. On the left side and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please call your service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group. Done
Dec 23, 2010 | Saeco Spidem Villa
Spidem brew group stuck in machine in wrong position.
Hi
Remove the dredge drawer as far as you can. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Jan 09, 2010 | Spidem Cappuccino Instantly Espresso...
After a cleaning of the group, we're not able to put it back
First step: You need to make the machine think that the group is in place.
Solution: This can be done by locating the three microswitches that need to be set. Turn machine on/Open the door/insert wastetray&dredgebox (switch One)/with plastic stir stix(noconductive material) active brewer microswitch located in the centre of the back wall/with plastic stir stix(noconductive material) active door microswitch located top right side behind door. All 3 switches need to be actived simutainiously with the power one. When installing the brewer, be sure that the microswitch activator slide on the back of the brew group itself is in the up position.
Note: if you do not know what I was talking about(microswitches) best not to attempt
Apr 13, 2009 | Saeco Incanto Rondo Fully Automatic Coffee...
Vienna superautomactica found a spring
That spring can fit in many places:-(
I put a blowprint of the brewingunit here.
Jan 31, 2009 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Saeco INCANTO DELUXE Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
