Question about Topeak Cycling
Topeak Pocket Shock pump~ can't find instructions... attempted to use but seems like I loose air..... help
    Guru:
  • 347 Answers
When you place the pump head on the valve make sure you flip the lever, this will seal the pump and air will not come back out. Also make sure your valve is not bent or loose. If your still losing air take the pump and bike into any bike shop and they will be more than happy to show you how to use it, and bonus if there is something wrong with either the tube or pump they will be able to diagnose and provide a solution.
Posted on Apr 07, 2011
Topeak mini G dual pump
You are most likely using the pump set up to work with a Schrader valve when you should be using it with the internals set up to work with a Presta valve. This video will help you identify the valve type and explain how to change the internals of the pump: http://www.topeak.com/pages/368/news/detail/832
This video will explain how to change a flat:http://www.topeak.com/pages/368/news/detail/830
I hope this helps, Eddie O - Topeak Inc
Nov 15, 2012 | Topeak Mini Master Blaster
User Manual l for topeak 140
Go under service, downloads, yada yada
Mar 10, 2011 | Topeak Comp 140
I have a Topeak Mini DXG MasterBlaster pump and Schroeder valves on my bike. I can't make this pump work, it seems to not press the stem down. Do I insert the valve with the lever down and then pull the...
I have the DX, and I only use it for Presta valves. With mine, the lever is down to insert it onto the valve, and up for inflation. On yours, the head probably unscrews, and the black rubbery piece the grabs the (Schraeder) valve might be inserted wrong-side out. It's easy to remove this piece and put it back in the other way. This might be the problem. Be careful to do this over a clear area, as the pin in the pump might fall out. If it does, no big deal, just put it back in. Probably stating the obvious, but make sure the pump is seated on the valve stem all the way. Good luck!
Apr 22, 2017 | Topeak Peak Master Blaster Dx Pump
Pump will not draw air back in after a pump.topeak master blaster mini dx
I think I know your problem: The valve at the bottom of the pump which controls the in-out flow of air can get clogged largely with residue from the gasget as it wears. My suggestion is to take the pump back to the shop where you purchased it as Topeak usually honors its lifetime warantee.
Jan 18, 2011 | Topeak Road Morph Pump with Gauge
How do I switch the Topeak mini master blaster pump for presta valve operation? It looks like there's a plastic washer that needs to be reversed but it's impossible to remove.
i've just bought one, they seem pants, un screw the cap, theres a remove the rubber part, tap out the green bit, then just switch it round.
but i've tried pumping my tyre but nothing seems to happen
Sep 03, 2010 | Topeak Mini Master Blaster
I have a topeak master blaster pump, and it is set up for schrader valves. I cannot fathom how to change it to a presta adaptor? There are no parts that came with it and I cannot see how the adaptor is...
remove the cap, pull the rubber bit out, tap out the green bit, then switch it round, but this is where your problems start, as it does not seem to pump the tyer up.
Aug 09, 2010 | Topeak Mini Master Blaster
Cycling Logo
208 people viewed this question
Top Topeak Cycling Experts
numbers819
Level 1 Expert
dante
Donald Ayers-Marsh
Are you a Topeak Cycling Expert? Answer questions, earn points and help others
