Question about Aqua Vac Tiger Shark
When plugged in my aquavac only will roll on one side the other acts like it is stuck.. is there a way to correct this?
    President:
  • Aqua Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
You can check the 'stuck' side for items such as swim goggles, dive toys, clothes and the like - remove anything you find. If there is nothing jamming the track then either a bearing is shot or some other portions of the moving parts are damaged or broke. You can remove the side plate by backing out the 4 or 6 screws found inside the unit behind the filter. Once out you can force the side plate off to expose the track and pulleys. It should become obvious at that point what is jamming the unit and proceed to fix it.
If you need parts or more advice please comment to this post or contact us thru our site below.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 07, 2011
How do I replace side cover with plug
You have to take off the handle, then from inside the unit remove the side panel screws ( about 6 I think, its been awhile). Remove the cord strain relief plate, now remove the cord from the motor. There is a special torque wrench for putting this cord back in to ensure a water tight seal. It can be done with needlenose pliers but you may be setting yourself up for a new motor if you don't get it right. Once cord is off motor you should be able to pull side plate and motor off, then reverse steps to te install new.
Aug 23, 2016 | AquaVac Tigershark Plus Robotic Automatic...
My feed tray is stuck. It is not in the correct position and there seems to be a little tab stuck on the left hand side. Help, please!
The pin on the left side is used to actuate a safety switch. It must be in the small hole or the machine will not power on. It is spring loaded, so pull it to the right to release the tray.
Aug 27, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
My ford f250 rolls when in park
The park unit is a pall the fits into square shaped notches in the gear box on a planetary gear and so acts as a lock . If it is not working it may be because the pall is not in the correct position to engage ( check selector lever adjustment) it is stuck or the square segments are no longer square but "v " shaped
Mar 18, 2014 | Cars & Trucks
2000 Honda Passport Window Issues
Hi
I would think you either have a fault control unit in door or a poor connection.
Roger
Apr 24, 2017 | 2000 Honda Passport
The paper drawer is stuck on my new Samsung CLP 310
Turn the printer off. Unplug it completely. Very Carefully, roll the printer onto one side. Push the paper drawer in as far as possible, then, by grabbing the bottom of the paper drawer, and the front of the drawer with your opposing hand, slowing slide the drawer to release the pressure and slide it out at the same time. Pressure from the rollers pulling paper from the drawer will jam the paper between the drawer so tightly that the weight of the machine will act as a clamp. When your remove the weight of the machine by rolling it on it's side, you can slide the drawer out easier.
Nov 15, 2010 | Office Equipment & Supplies
Driver's side power window will not roll up
Sounds like wear and tear on the guides/seals.
May 19, 2009 | 1995 Honda Accord
Passenger side window not rollin up properly. 2004 Mustang
i think ur window power motor need to change
Apr 17, 2009 | 2004 Ford Mustang
Tiger shark will not move
The motor that drives it forward and back is seperate from the fan and is defective unless your stuck on the main drain the motor unit needs replacing.
Mar 14, 2009 | AquaVac Tigershark 2 Commercial Vac with...
Paper feeds as if normal but no printing appears on paper
If it is now printing blank and was working before the paper roll change then you need to flip the roll over and print on the other side of the paper. This is assuming you have the correct thermal paper roll.
Dec 09, 2008 | Office Equipment & Supplies
Aqua Vac Tiger Shark Logo
165 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
