Question about Whirlpool Washing Machines
Our 3 year old front loader washer viberates excessively. It is level, the floor stable and capable of supporting this kind of weight and we put extra anti-skid pads under the legs. I avoid heavy loads because the viberation is absolutely violent with them. I I am always afraid of doing damage to the tub and balance system so when it is viberating too much, I stop it, wait until the clothes (always a moderate load) completely settle, then start again and sometimes it's better. We don't know anything else to try and it's very disappointing to have had this problem with such a new machine. In the first 6 months or so, the machine ran quitely and preformed well but it became worse with time. We expected some viberation because of the rapid spinning motion but not so much that it actually walks a bit on the floor. And I assure you we check for levelness often and it's always level. Any suggestions?
  • 822 Answers
Might be..... the suspension or springs holding the drum......
cheers
Posted on Apr 07, 2011
In spin cycle violent vibration
First, check to make sure you aren't loading the washer excessively. Many times it is an unbalanced load. Second, check to see if the washer is level. The feet are adjustable and allow you to level the washing machine. While checking the level, make sure the floor underneath is stable as well. Lastly, if these do not help, you may need to have the dampners checked (these are like shock absorbers and minimize the vibration of the drum).
Apr 15, 2014 | LG WM-2277HW Front Load Washer
Tip
Front Loader Excessive Vibration
When the manufacturers first introduced the front load washers, they did not take into consideration the possible problems created by the centrifugal force of the washer's spinning action. Most of these washers spin in excess of 1200 rpms! A spinning action that fast, coupled with the washers heavy weight and a floor that flexes (even a little) will cause a resonant vibration. In simple terms, it will cause the washer to bounce or walk.
Some of the early manufactured shock absorbers, weren't up to par and were uable to maintain the washer suspension over continuous use. The manufacturer's improved the shock absorbers to make them more stiff and minimize vibration. Replacing the shocks with heavier duty shocks does help, but if the flooring is not substantial enough the washer will continue to have problems.
If the washer is mounted on a pedestal, this can make the problem worse. Early model pedestals had an open back which caused it to "tin can" when the washer spun. "Tin-canning" is the phenomenon of the sides of the pedestal casing waffling in and out as the weight of the washer rides on top of it. This would also cause excessive vibration. The solution: The manufacturers redesigned the pedestals with an enclosed back that would prevent this from happening. If your washer is a later model, you should have an enclosed back on the pedestal. If there is no back panel, a stiffiner kit can be purchased and installed by any Do-It-Yourselfer. All you need is a drill and a screwdriver. Instructions are included. The part number is 134682000. I found it listed at searspartsdirect.com.
Check the leveling of the washer. You need to adjust the feet of the washer ensure it is level front-to-back and side-to-side. The feet are adjusted using a wrench to turn the legs up or down. Use a level to check your work. Once completed, you should be able to place your hands diagonally across opposite corners of the washer top and see if the washer moves at all. If unlevel (just the slightest) the washer will vibrate during the spin cycle. If the washer is mounted on a pedestal, you level the feet of the pedestal, NOT the washer. Make sure the washer is firmly mounted to the pedstal fisrt. Then, level the feet of the pedestal using the same procedures outlined before.
Another cheap method to get rid of vibration is to use foam padding to sandwich between the sides of the washer, the dryer and the wall. Swimming pool noodle foam works real well and is very inexpensive. About $3 or $4.
Overloading the washer with heavy items can cause excessive vibration due to an unbalanced load. If you load items so full that you can barely close the door, the load will have a hard time distributing evenly around the perimeter of the wash tub. Once wet, and the tub begins to tumble, the load becomes entangled and will pack on one side of the tub. This will cause the washer to jump and walk across the floor on the spin cycle. This can also cause premature wear to the door bellow, damage to the door latch and damage to the shock supports and counter-weights. Always follow the manufacturer's wash load recommendations as outlined in your owner's manual.
Now...when you've checked every other possibility, its simply not the washer. Most consumers don't like to hear this (especially owner's of newer homes). The worst places you can put a front loading washing machine is in a mobile home, or an upstairs laundry room. The floors in these areas are usually not as reinforced. Even homes with a laundry room over a crawl space or basement can sometimes have problems if the floor flexes. Most home builders don't take added reinforcement into consideration for the installation of a front loading washer.
An inexpensive way to reinforce a laundry room floor is to install a 4 x 8 sheet of heavy plywood under the washer. The plywood has to be a minimum of 3/4 inches thick and needs to be secured (screwed down) to the existing floor. This distributes the weight of the washer better. You can also safely fit BOTH the washer and dryer on top of it. A lot of people don't like this idea, because they feel it wrecks the look of the existing floor. I have seen homeowners, install a reinforcement this way and add paint, trim molding, and even tile to give it that "supposed to be there" look.
You may get mixed reviews about this, but I have seen it work for homeowners. Plus, its a less expensive option than hiring a contractor to firm up your sub-flooring or joists.
I hope you find this information informative and helpful. If you have questions, please let me know.
on Dec 13, 2009 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer My washer & dryer are brand new 2 days old! I have ran about 8-10 loads through them now and EVERY time the washer spins it vibrates the whole house. The...
There's a few things that cause this and there may be no easy answer. Is the washer on the second floor? Is the washer on a ceramic tile floor? ...wait a minute, you said it vibrated the whole house so this makes me think the floor has some "give". If any of these there is no easy fix. I've seen ONE thing that does work though. It's a pedestal that spans under the washer AND dryer, one long one which distributes the weight and vibration. I don't know where to get one but I do know they are out there. One of my customers had one and I took notice because the floor was ceramic tile and the washer wasn't vibrating all over the place. It was very stable.
Oct 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer doesn't sit level in new laundry room
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to check properly for internal issues,unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or rocking, is the floor on which the washer sits. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 23, 2010 | GE WSXH208A Front Load Washer
My front load washer "walks across the tile floor", it is level, what can I do
Unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or clunking, is the floor on which the washer rests. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front panel
i am sorry to say but that is true the machine will shake if on a wood floor if the duet is on a concert floor it does not shake as much
Apr 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spin vefy fast
A rapid spin cycle is actually a GOOD thing. This is an indication that the gearcase (transmission) and the drive motor are both running strong.
If the washer shudders during the spin cycle the first thing you need to do is check to ensure the washer is properly leveled. The following link explains:
http://www.fixya.com/support/r3868923-level_whirlpool_top_loading_washer
The model Whirlpool top loader you have, has an auto-leveler mechanism on the back two legs that can become unlevel periodicailly. You should check the washer level from time to time when it is empty. You need to also make sure the washer is level in ALL directions (front-to-back and side-to-side).
Accidental unbalance problems that can occur from washing blankets, comforters, or heavy loads of towels can also cause the washer to become unlevel and shake. This can also contribute to the level mechanism becoming unbalanced.
Overloading the washer can also cause unbalance problems. Washing blankets or conforters can cause the load weight to shift to one side of the tub. This will result in a tub that shakes violently and bangs against the cabinet. You may have to redistribute the load weight when washing heavy items. This can also occur when washing loads of towels. This is NORMAL as some heavy items do not distribute the weight evenly.
Another problem (which is less common) that can contribute to wash unbalance problems is a weak floor under the washer. If the floor flexes (even the slightest) during the spin cycle, it can cause the washer to bounce or shake. Mobile homes or laundry rooms on the second floor of a home are notorious for having weaker floor structures. This washer has a 35 gallon tub capacity. Coupled with the weight of a wet load and the spinning action, this can put a lot of centrifugal force on a floor.
If you have any questions or concerns, please post back and let me know. I hope this information is helpful to you.
Apr 25, 2010 | Whirlpool LSR5132PQ Top Load Washer
Duet Vibrates the whole house on the spin cycle. it has started this only when we recently moved.
The key statement that you made was the fact that you recently moved. Some questions you may ask yourself:
Where was your washer installed in your old home as compared to where it is installed now?
Did you re-level the feet after you moved the washer?
Did any of the shock mounts come dislodged during the move?
Is the flooring in your new home substantial enough to handle the weight and spinning action of a front loader?
The following link can give you some things to consider when trying to figure out what may be causing excessive vibration:
http://www.fixya.com/support/r3633026-front_loader_excessive_vibration
You may not like hearing some of this, but I can assure you, I have dealt with this problem numerous times. In the majority of cases, substantial flooring was causing the problem.
Read through the link provided and let me know if you have any questions. I hope you find the information helpful in some way.
Mar 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to keep the floor from vibrating while in spin cycle
Most likely cause of vibration is that the washer isn't leveled. Use a torpedo or carpenters level and adjust the support feet on the washer to get it level. If it still makes the floor vibrate, you may have a soft floor. You could then try putting a piece of 3/4 plywood under the washer to help support the weight.
Feb 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Walking Washer
due to weight and normal motion during wash/spin a very sturdy floor is necessary under front loads also some floors are a little slick and sliding may occur ck for weak floor and maybe some kind ok rough cushion under feet to reduce sliding also if on pedistals even more vibration may occur be sure all screws in pedistal are secure usually 4 from top onto bottom of washer also adj legs to lower unit as close to floor as possible and tighten lock nuts
Apr 25, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
