Question about Vacuums
I need to replace the seal in my Barista's boiler. What size nuts are those holding it together? I can't seem to get them off. Also, what would be the correct way to get that arm that goes to the steam control off? I'm assuming it needs to come off to put the new seal on and I don't want to break anything.
  • 1 more comment
  • designsonpap Apr 07, 2011
    This is not a vacuum! It is a Starbuck's Barista espresso machine. Made by Saeco. It is leaking around the boiler and the nuts are rusted.
    Since I had already pulled down espresso machines I didn't think it was necessary to reiterate these facts.
    So, in case you have misplaced my original request; what I want to know is what size the nuts that hold the top of the boiler down are, and the best way to remove or loosen the arm that goes from the boiler to the steam wand.
  • designsonpap Apr 08, 2011
    Thanks for your answer.
    It's leaking water. Big Time! I am going to replace the seal.
    Do you happen to know the answer to my second question?
    Also, what size socket wrench do I need to remove those BPT screws?
  • designsonpap Apr 10, 2011
    No, I'm not refering to the port-a-filter. I said and meant the boiler (inside the machine.)
    I'd like my money back please.
    You don't seem to have anyone there who can read.
  • 794 Answers
Hi designsonpap,
I'm just wondering if you are referring to the Portafilter when you are asking on the best way to remove the arm that goes to the steam control.
The portafilter looks like this:
If this is what you mean follow the steps below:
1. Turn the portafilter handle clockwise to unscrew.
2. Flip the portafilter over so the plate with the 3 screws faces up.
3. Unscrew then remove the 3 screws.
4. Take off the metal plating that comes loose after removing the screws. This will expose two internal springs.
5. If springs are still sturdy, then reattach them. If the springs are distorted, then replace them with new springs.
Hope it helps.
Thank you for using Fixya.
Posted on Apr 08, 2011
  • 4,399 Answers
Thanks for choosing FixYa. What type is this please? Is this the one with the 6 screws on the back plate? What exactly is going on?
Posted on Apr 07, 2011
  • Richard Hale
    Richard Hale Apr 07, 2011
    They are 3/8 BPT, which is British Pipe Thread.
Were to find replacement battery pack
I would suspect that they would only be available thru DIRT DEVIL
Jan 03, 2016 | Dirt Devil BD10165 Gator Bagless Hand Held...
Eureka 9410 upright vacuum motor
They normally have a reverse thread nut on top then just pushed down on a tapered end so needs to be levered off normally a wide flat blade paint scraper etc can help spead load so fan doesnt break or distort
Apr 13, 2017 | Vacuums
How to fix a fan that goes off when put on higher option
That depends on whether the problem is a bad high-speed contact in the switch or an open winding in the motor. It's more likely to be a switch problem. In the best case, you can spray contact cleaner into the switch and it will work. Otherwise, you may have to replace it.
If you are really handy, you can take the switch apart (you may have to drill out a couple of rivets), polish the contacts, then put it together with some small screws and nuts - probably #2 size. If you do this I strongly recommend using a thread locking compound on the screws so the switch doesn't fall apart while the fan is running. If you can find replacement rivets in that size, that's a better way to go. Some fan switches are glued together or snap together; you'll have to examine yours to see what you have.
May 31, 2011 | Vacuums
My floormate leaks water on the floor in puddles, even when I am not holding down the lever to wash.
Ok when replacing the Spring stem and rubber seal. Put the spring on the stem set it in the hole of the solution tank carefully hold it steady then pull the stem out slip the rubber seal onto the stem with the cupped side facing down toward inside of the tank press it over the rim on the stem so it stays in place then take the stem slip it into the solution tanks hole inside the spring and press the rubber seal into the inside of the tank.
I posted this so no one else goes threw the trouble I went through until I figured it out for my self I lost the parts and did not remember how the thing went back together and could find no help anywhere. Good Luck, Ray
May 26, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
Tristar vacuum has wiring pulled loose inside and I cannot figure out how to open the vacuum. It is a 1997 model. It appears that the rubber seal is holding the two halves together.
I have the same problem with my older '80s Tristar.
This may work for your model, give it a try.
On mine, there are 3 phillips head screws holding the two halves of the cleaner together, and the rubber bumper.
You have to remove the screws first. Your model may have more or less screws.
On mine, there are two screws near the front wheels, down deep. I had problems taking them out, but not to worry, once they are loose, they are no longer holding the other half, don't worry about taking them fully out.
Also, at the rear, there is a small black plastic clip that has a screw in it. You'll need to remove that too. Once all the screws are removed, use a medium sized flat head screwdriver to go behind the rubber seal -- you're looking to get the screwdriver to where you can see or feel the edge of the canister. Simply twist the screwdriver a bit and the canister should feel like it's coming apart. Mess around with that for a bit, and the parts should come apart easily.
May 02, 2011 | Tristar Vacuums
How do i splice the power cord back together
You will need to cut away the outer rubber insulation. Be careful not to cut the insulation on the 3 separate wires. Then you will need to remove about three fourths of a inch of insulation from each of the three wires. If you can solder, then solder the black to black, green to green , white to white. Then Tape with electrical tape each wire separately. Do a good job of taping. If you cannot solder, then go to a hardware store a buy # Wire Nuts. Take the loose end of the cord with you so as to get the right size of Wire Nut. The wire Nut repair is bulky , but secure. You are using a lot of Amps with the Steamer so you want a good job, lest the repair gets hot. Either repair I mentioned will work safely and well.
Good Luck !!!!!!!!!!!
Jun 25, 2010 | Eureka Atlantis 2591A Upright Steam Vacuum
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Don´t know how to take my Rainbow apart.
Your model is a bit newer than mine, but on mine, I have to peel off the foam rubber gasket that seals the canister to the top of the vac when you put it together. You will have to replace this gasket once you peel it off. Under the gasket are the screws that hold the top cover on.
Hopefully your model is similar to mine, and this is the answer you need!
Nov 06, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Solution seals
Please use the following link:
http://www.hoover.com/parts/?category=carpetcleanertanks&part=42272134
This is for a replacement solution tank assembly
Sep 09, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Henry hoover - occasionally it won't **** and I can usually sort it out. This time it just won't **** anything up.
Hi, Have you checked the hose for blockages and also the only main problem with these are you know when you take the top off then their is that big round filter that sits on the lip that holds the two parts together, Check this is in the correct way and that the seal is not damged check also the clips holding the top and bottom together are secure.
But blow down hose make sure not blocked then check the filter this might even need banging to remove dust in case its built up to much and not allowing the air to get through it ok
Let me know how you get on ok
Apr 23, 2008 | Vacuums
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
