Question about Dell Latitude D410 Notebook
Where can i find the process to change a D410 inverter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Posted on Apr 07, 2011
  • Willie Stovall
    Willie Stovall Apr 07, 2011
    Please rate this solution.
Lg inverter 2400btub..timer light 4blinks and returns to power light. This process repeated.
Change the inverter board if you are sure that the screen is ok . you can look for another tft lamp or led strip to test your inverter since u did not specify may be led or tft inverte ,if it light correctly then prepare to change your screen back light ,if not u change your inverter
Jun 26, 2015 | LG Televison & Video
Where is the @ key on the dell latitude D410 keyboard
To get the @ key hold down the Shift key and then press the number 2 key
May 19, 2012 | Dell Latitude D410 Notebook
HOW DO I SWITCH ON BLUETOOTH ON A LATITUDE D410 LAPTOP
Bluetooth is an option in the D410. See the manual to check whether your device has bluetooth. If yes, then you can enable bluetooth by pressing the Fn Key + F2. There is a Bluetooth LED indicator light to show when Bluetooth is enabled.
Jul 18, 2011 | Dell Latitude D410 Notebook
How to restore setting on my laptop dell latitude d410
Restart the computer and as it is restarting Press F11 and follow the on screen instructions. If this does not work then one, change is necessary which is, as the computer is restarting ,Press F11 and CTRL together and follow the on screen instructions. Some times the key combination is different so try F10 if the above does not work. good luck
May 12, 2011 | Dell Latitude D410 Notebook
How do i restore my dell latitude d410 with out a disc?
Turn the computer on, after you see the "Dell" logo, press and hold Ctrl then press F11, then release them both at the same time. If that dosen't work after the dell logo contunilusly press Ctrl and F11 repeatly at the same time and the dell recovery partition wizard should show up. Source(s): Dell service Repair Expert
Nov 30, 2010 | Computers & Internet
Dell d410 lcd display is dim
may need an inverter or replacement lcd if the bulb in the lcd is damaged. The Good neews is that 98% otf the time a display ges dim tth inverter is the cause and its abit easy to replace.
heres the inverter
http://cgi.ebay.com/Dell-Latitude-D410-Inverter-Board-12-1-LCD-IV11176T-LF-/370391713650?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item563d110772
Jun 19, 2010 | Dell Latitude D410 Notebook
HOW TO REASSEMBLING MY LAPTOP FOR DELL D410?
Here's a link to the service manual for the Dell Latitude D410:
http://support.dell.com/support/edocs/systems/latd410/en/sm/index.htm
This service manual describes in step-by-step how to disassemble/re-assemble this laptop model.
Jun 12, 2010 | Dell Latitude D410 Notebook
Can't find microphone on dell latitude D410 to skype
Checked on the Latitude D410 and it does not have a internal microphone ... the microphone connector is located on the right side of the laptop near the back ... you will need to purchase a separate mic to get this functionality ... these are fairly cheap to purchase
Mar 25, 2009 | Dell Latitude D410 Notebook
Dell Latitude D410 Notebook Logo
269 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
