Question about Samsung Office Equipment & Supplies
Message comes up replace imaging unit soon.What is this?
  • 85 Answers
Image is normal wear to a certain number of units calculated according to the tehnic(user) manual .Se pages may continue to use the printer until you consider that the image you want to buy another unit or until you notice that not print correctly
Posted on Apr 07, 2011
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
How to clear notification transfer roller needs to be replaced soon.
1. Touch Menu.
2. Touch [Counter].
3. Touch [Display Keypad].
4. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
5. Enter the CE password and touch [END]. (IF required)
6. Counter
7. Life
8. Transfer Roller Clear
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 19, 2015 | Genuine Konica Minolta Konica Minolta...
I get a loud noise from the drive unit of bizhub C35, and the machine comes up with an error message to install Black IU. I had replaced the black IU twice now and also had replaced the whole drive...
First using alcohol clean the electronic chips under the image unit. and the contacts on the printer. Also shake the image unit side ways to ensure all of the developer and toner are spread along the whole body of the image unit. DO NOT STORE IMAGE UNITS UP AND DOWN!. DO all the image units. Might have a bad image trans belt and or fuser unit.
Feb 20, 2015 | Konica Minolta bizhub Office Equipment &...
I have a Konica Minolta bizhub C351 that has an error message " transfer roller unit needs to be replaced soon" I purchased and replaced the "image transfer roller unit 4049-411 that also has the nu
Enter in the service mode:
Press Utility key - Meter count - Details - Counter mode - select present parts life and reset(clear) the transfer roller counter.
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
Re: Samsung Printer CLX3175FN -- receiving message "Replace imaging unit soon." I've read other expert replies but am still missing some information. Can I replace the unit myself? How do I do...
Nancy, Your imaging unit has a limited lifecycle. Documentation states that it can make 24,000 B&W pages and 6,000 color. The message is telling you that you are getting close to that limit. Eventually you printer will stop printing, and your messahe will state "Replace imaging unit". This can be done by you. It is very easy to do. The imaging unit is fairly expensive: around $150 or more depending on the merchant and shipping charges.
Drew
Feb 16, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Phaser 7760 Error message: "Imaging
The black image unit of your machine should be replaced soon. It is a maintenance item and is very easy to change. They cost about $350 new, but you can buy one much cheaper rebuilt. Here is a video I made to help explain what it is you need to change and how to do it. Good luck
Nov 16, 2010 | Xerox Phaser 7760/YDX Laser Printer
Sir, i am using Konica Minolta C252. I am getting error message C-2553. If i opened the front door and closed then the error message will go, but again it will come after some copies. What is the problem...
Magenta Image unit mite be the problem have it replaced if it already was then mite have a bad new one also check the sensor that monitors the toner for the magenta Also pull out the magenta image unit shake side to side to spread out the develop inside the image unit along the entire length of the image unit reseat the image unit.
Aug 20, 2010 | Konica Office Equipment & Supplies
Brother 8360p says change drum soon
You have to open the front door and then press options, should see Replace Drum? just answer yes.
Sep 09, 2009 | Brother MFC-8440 All-In-One Laser Printer
Samsung clx-3160fn change image unit
Kindly take out the imaging unit out of the printer and take out and put it properly.
If this did not fix you may try using the imaging unit from other printer.
If this did not solve then visit a service center or buy its Imaging unit.
May 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Message received drum life end soon
The message means the imaging drum is going to need replacement soon. The imaging drum and toner cartridge are the two main parts that need replacement sometimes. In some printers the drum and toner cartridge are replaced in the same unit, but the Brother has separate parts. The drum is rated for a certain number of copies, so as it gets close you get the message. Replacement drums are available at big-box office places and online. An original Brother is in the $100-$150 range and generics around half that cost.
Apr 01, 2009 | Brother MFC-9440CN Laser Printer
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
