Question about Armitron LCD Sport Chronograph #40/8139SVDG Watch for Men
How do I turn off the birthday mode on my watch (Armitron 40|8139SV)
WHERE CAN I FIND THE MANUAL FOR THE ARMITRON 40/8284 PRO SPORT WATCH?
hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
Instructions to Set the Time on an Armitron Pro Sports Watch
or try this.
How do you set an armitron pro sport watch? Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
Instructions to Set the Time on an Armitron Pro Sports Watch ...
https://www.livestrong.com/.../247211-instructions-to-set-the-time-on-an-armitron-pro-s... Search for: How do you set an armitron pro sport watch?
or read up on this link.
MANUAL FOR THE ARMITRON 40 8284 PRO SPORT WATCH Google Search
Nov 29, 2017 | Armitron Watches
Set the time on a Armitron WR330 40/8125 All-Sport watch
Hi jerryurq51,
Please follow these steps to set the time of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Apr 22, 2011 | Armitron 40/8125BLK Digital Sport Watch
I need set the date of my Armitron watch Thank you
Hi diazlieter,
To set the date of your Armitron watch, please do the following.
Hope it helps.
Feb 14, 2011 | Armitron 40/8125BLK Digital Sport Watch
How do i set the time and date on my watch?
This is direct link to all ARMITRON watch manuals/instructions: http://www.armitron.com/watch_instructions.asp
or
You can also try with this approach. This is for Armitron WR 330,but i believe this could also help you.
The following labels are on the inner ring of the watch; I've given their positions relative to where numbers would be on the face of an analog watch.
"ST/STP" is at 2:00; "EL" is at 4:00; "MODE" is at 8:00; and "ADJ" is at 10:00.
To set the time, date, and day of week:
Press and hold in the "MODE" button until the display starts flashing. (This is the alarm time.)
Press the "MODE" button again; the seconds begin flashing. Press "ADJ" to set them to zero.
Press the ""ST/STP" button to change what you want to set. The options appear in this order each time you press the "ST/STP" button: minutes, hour, month, day, day of week.
Use the "ADJ" button to change the value of the setting.
Touch "MODE" to save the settings and return to time mode.
Thanks for using Fixya. Please rate the solution.
Nov 06, 2010 | Armitron 165 watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
This watch comes with a Birthday Alert feature, I believe. How does one set the day of the birthday? Mine went off at 1:00 a.m. on 1/1...not my birthday! Thanks for the help
Go to the "Amitron" web site.
Select "support"
Select "watch instructions"
Scroll down illustrations to find the one that fits your model and download instructions.
Jan 02, 2010 | Armitron Digital Sport #40/8132BLK Watch...
How to set armitron digital watch 45/6915?
Assume A B
C D
To turn off the alarm press & hold A then press B, do this several times until your alarm/chime is either on or off.
Jul 18, 2008 | Armitron Watches
Armitron Watches
From the time telling mode press the set button the seconds will flash.
Press the mode button the hours will flash
Press the adjust button to change the hours
Press the mode button the minutes will flash
Press the adjust button to change the minutes
Press the mode button the month will flash
Press the adjust button to change the month
Press the mode button the date flashes
Press the adjust button to change the date
Press the mode button the day flashes
Press the adjust button to change the day
Press the set button when done.
Mar 11, 2008 | Watches
Can't set time on a 2 button armitron watch
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
Mar 10, 2008 | Watches
Armitron LCD Sport Chronograph #40/8139SVDG Watch for Men Logo
67 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Stan Ford
Are you an Armitron Watch Expert? Answer questions, earn points and help others
