I have a lg plasma monitor model MU42PM11 and need to factory reset it ,no input will give me a picture
  • frankcolozza Apr 07, 2011
    the monitor I believe was used with a set top box and worked ok until I tried to use cable tv with it, I think if possible it was configured thru the box to work with the box and I don.t no how to configure it so i hoped there was a default to factory settings I could do. thanx
  • 10,515 Answers
I am sorry to hear regarding the trouble. The situation you are describing is highly suggestive of ' Hardware Failure '.For future reference, you will need to go into your menu under "option" and scroll down to "factory reset" and select "yes".However, as you do not see any picture, which sets itself more as an internal failure than any other issue. If the set is under warranty, i would advise you to call LG, however, if it is out of warranty, you need to either get it repaired yourself or send the unit to service center. If you do not have any prior TV repair experience, i would advise you to send the unit for repair, however if you have prior experience, kindly revert so that we could proceed.
Note - You could unplug the TV for few minutes, say 15 minutes and then turn it ON. Sometimes, this would fix small internal problems.
Thanks and Regards
taran_2005
Posted on Apr 07, 2011
  • taran_2005
    taran_2005 Apr 07, 2011
    Thanks for your response!!
    Unfortunately, there is no SUCH settings which would make this monitor worked only with top box. This is a common problem on this set and discussed in many forums. I am sorry for such a bad news,however my job is to provide you with the most feasible solution than any run around solutions. You could try to play with the cable and see, if there is any response. However, if the monitor is still dead as dodo, it would confirm an internal failure.
    Thanks and Regards
    taran_2005
No inputs working
possible mainboard isn't fuctioning right try reseting the tv from the menu to factory setting and trying again
Jul 14, 2014 | LG 42PG20 42 in. Plasma HDTV
I have pink color horizontal lines on my LG LCD monitor screen,How do i solve it?
You can fix you have to follow this instruction
1-Reset the TV by unplugging its power cord for 30 seconds and plugging it back in. This is an essential troubleshooting tool as a simple reset often will resolve the great majority of technical issues experienced by any kind of TV. Power the TV on after plugging it back in and check the picture for any improvement.
2-Unscrew the coaxial cable that attaches your wall cable outlet to either the coaxial cable input on the plasma TV or to any digital cable converters you may use at home. Check the copper needle in the middle of the cable for any bending or damage and screw the cable back on the coaxial input. Again, check the picture for any improvements.
3-Secure the audio/video connection cables that attach the source device you are trying to watch to the plasma TV. This is a particularly important step if you use component cables. Component cables separate a video signal into different colors, so a damaged or loose component cable can lead to noticeable discoloration on the screen. Once the cables are secure, both in the source device and the plasma TV, check the picture again to see if this may have resolved the issue.
4-Scan your channel lineup and check the other TVs in your home to determine the scope of the problem. If you see the discoloration only on one or a few channels, and the same channels are discolored on the other TVs in your home, you may be part of a cable service outage and you will need to report the issue to your cable provider. If all the channels on the one TV have the same discoloration, and the other TVs in the home look normal, the plasma TV likely will need to be serviced for a problem with its picture components.
hope that it helped
Feb 18, 2014 | LG 22" FLATRON LCD Monitor
I have a lg 42 " plasma model LG42PX5D It has a snowy picture even when I play DVD
Are you using a direct input for the DVD or going through the tuner?Use one of the aux inputs and check that way.
Oct 30, 2013 | LG 42PX5D 42 in. Plasma HDTV
Cant change the input mode on my LG 50pq60d. its in antenna mode and will not change to av
I think this calls for a phone call to LG customer service to see what can be done and to inquire if this is known issue in this model--all these companies keep extensive records or model versus problems.
May 01, 2012 | LG 50PS60 50 in. Plasma HDTV
How do I reset my lg plasma tv?
Press the "Menu" button on the remote, then scroll down to the "Picture" setting and press the "Enter" button on the remote. Go to "Screen" and push the "Enter" button, then go to "Reset" and press the "Enter" button again. It will ask you to confirm the reset order. When you do, the image will reset to factory settings.
Read more: LG Plasma TV Troubleshooting ' eHow.com http://www.ehow.com/way_5347793_lg-plasma-tv-troubleshooting.html#ixzz1GjxxXQKI
Hope this helps! -jayps
Mar 16, 2011 | LG Cell Phones
Model 60PY3DF plasma lg tv has no picture but has perfect sound. Can U help?
Try unplugging the receiver for ten seconds, if that fails check the cabling. Lastly, try cycling inputs by hitting your input or source button.
Daniel Busa
DISH Network Customer Service
Feb 10, 2011 | LG 60PY3D 60 in. Plasma HDTV
The AV2 HDMI are missing from the input list of my Plasma LG 42 ". Please help
Well, first question would be is anything plugged in, and is currently outputting any content? Some televisions will only display input devices that are being fed some kind of content in list form. Like my Westinghouse...when my PS3 is on, my little HDMI3 will show up with a square indicating content....when it is off....HDMI3 is not listed. I'm sure you can however manually scroll through inputs on your remote, and you will find your AV2 HDMI.
Mar 06, 2010 | LG 42PC3D 42 in. Plasma Television
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
