Question about Xerox CopyCentre C128 Black and White Copier
ERROR CODE 010-327 - Xerox CopyCentre C128 Black and White Copier
    Novelist:
  • Xerox Expert
  • 107 Answers
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Posted on May 29, 2011
5 Suggested Answers
  • 1382 Answers
SOURCE: code 010-327
These are the possible codes and the reason for occurence of this code in your copier
010-150, 155 -Too much or not enough paper in duplex tray
010-300 --Fuser thermistor, 010-302 --Low fuser temperature , 010-304-- Bad fuser temp, 010-308 --High fuser temperature or open thermistor, 010-310 --High fuser temperature , 010-312 --Fuser not up to temperature after energy save, 010-314 --Fuser problem , 010-320 --Fuser web finished , 010-330,327, 335, 340-- Exit switch, vertical sensor switch actuated when power is turned on
Thank you!!
Posted on May 18, 2010
SOURCE: error 010-327 workcentre 5230
machine show error code of 010-327. how to correct this error
Posted on Jun 03, 2011
goodgold
  • 389 Answers
SOURCE: XEROX WORKCENTRE 5222/5225/5230 A FAULT OR
010-150, 155 Too much or not enough paper in duplex tray 10-300 Fuser thermistor 10-302 Low fuser temperature 010-304 Bad fuser temp 10-308 High fuser temperature or open thermistor 010-310 High fuser temperature 010-312 Fuser not up to temperature after energy save 010-314 Fuser problem 010-320 Fuser web finished 010-330,327 335, 340 Exit switch, vertical sensor switch actuated when power is turned on
Posted on Sep 13, 2009
wrinaldo
  • 185 Answers
SOURCE: fault code 010-327
This is a fuser error, so we'd start by replacing that. The fuser PN is 126K16480.
This particular error code may be a false error, in which case either the Power Unit 105E11370 or the MCU Board 960K09910 might be bad.
Whit
Item, Inc.
Posted on Oct 21, 2010
How do i fix error code 42 on my cellphone? Help! Ive tried everything!
How to Repair Error Code 42 ' Windows Error Support - Error Tools
errortools.com/en/drivers/how-to-repair-error-code-42/
  1. Cached
  2. Similar
Code 42 Error is referred to as a Device Manager Error code. Before we explain what this code indicates, it is important to understand what 'Device Manager' is and its functions. Device Manager is basically a Windows tool that helps manage devices attached to the system such as the Printer, Scanner and the USB Device.
Error codes in Device Manager in Windows - Microsoft Support
https://support.microsoft.com/en-ca/help/.../error-codes-in-device-manager-in-windo...
  1. Cached
Lists the error codes that may be reported by Device Manager and the possible resolutions in Windows. ... Manager. If you are getting an error code that isn't listed here, you can contact the hardware device vendor's technical support or Microsoft Support for help. ..... Code 42 "Windows cannot load the device driver... (Code ...
ERROR CODE 42 - Boost Mobile Community
https://community.boost.com.au/t5/Setup-Phone-Support/ERROR-CODE-42/.../20989
  1. Cached
Sep 3, 2017 - 1 post Help! I can't send or receive text messages! It keeps saying: Error code 42 I can't call or receive calls either and I know that my bill isn't due.
Instructions To Fix Windows Error Code 42 - Error.info
https://www.error.info/windows/bus-driver-42.html
  1. Cached
  2. Similar
About the Error. The Windows error code 42 indicates the fact that the operating system has detected a duplicate device. This is usually caused by a sub-process that the system accidentally named incorrectly. Windows code 42 - Read what really helps. Though Windows error code can sound quite intimidating, fixing the ...
Dec 14, 2017 | Cell Phones
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
    Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Error code message
    What Does Your Treadmill's Error Code Mean? - LifeSpan
    www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
    Free
    May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
    [PDF]ERROR CODES: ADDITIONAL ERROR CODES:
    www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
    ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
    [PDF]Error Code Troubleshooting Guide
    Jan 19, 2016 | Exercise & Fitness
    The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
    LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
    Select
    Use our model number finder
    Choose your product type
    Common model number plates
    Close
    LG Refrigerator Error Codes
    These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
    Er FS Error Code
    Er rS Error Code
    F dS Error Code
    r dS Error Code
    Er HS Error Code
    Er IS Error Code
    Er SS Error Code
    Er rt Error Code
    Er It Error Code
    Er gF Error Code Error Code
    r dH Error Code
    Er IF Error Code
    Er FF Error Code
    Er CF Condition
    Condenser fan motor is defective Check/Repair
    Condenser fan motor, wiring or the control board Shop Parts
    Condenser fan motor, Power control board, Wiring harness Error Code
    Er CO Condition
    Communication error Check/Repair
    Communication error between main board and display board Shop Parts
    Display control board, Power control board, Wiring harness
    Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
    How to resolve erreur code E000051-0000 whith canon ir 2800
    the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
    List of top Canon Pixma error E500 codes
    Error code 1: Canon E500 Error Code E02 (E,0,2)
    • This error symbolizes that printer is out of paper or is incapable of feeding any document.
    Error code 2: Canon E500 Error Code E03 (E,0,3)
    • This error signifies the Paper Jam.
    Error code 3: Canon E500 Error Code E04 (E,0,4)
    • The error signifies that the "fine cartridge" is not installed accurately.
    Error code 4: Canon E500 Error Code E06 (E,0,6)
    • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
    Error code 5: Canon E500 Error Code E07 (E,0,7)
    • The ink absorber is complete and users need to reset the counter.
    Error code 6: Canon E500 Error Code E08 (E,0,8)
    • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
    Error code 7: Canon E500 Error Code E16 (E,1,6)
    • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
    Error code 8: Canon E500 Error Code E17 (E,1,7)
    • The front tray is totally closed.
    Error code 9: Canon E500 Error Code E30 (E,3,0)
    • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
    Error code 10: Canon E500 Error Code E31 (E,3,1)
    • The machine is surely disconnected with the computer.
    Error code11: Canon E500 Error Code E40 (E,4,0)
    • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
    Error code 12: Canon E500 Error Code E50 (E,5,0)
    • Scanning of the print-head alignment sheet has failed to function
    Error code 13: Canon E500 Error Code P02 (P,0,2).
    • This is a critical error which shows that the printer is in malfunctioning stage.
    Error code 14: Canon E500 Error Code P10 (P,1,0).
    • This error signifies that the mechanical printer is in total malfunction stage.
    So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
    May 16, 2015 | Canon IR-2800 Copier Reconditioned
    Erorr code 4003 zebra zxb8
    Error Code 4001
    System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
    Error Code 4002
    System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
    Error Code 4003
    System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
    Error Code 4004
    System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
    Error Code 4005
    System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
    Error Code 4006
    System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
    System Error Codes
    Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
    Xerox CopyCentre C128 Black and White Copier Logo
    11,721 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
