Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Kenmore french door freezer in bottom, stainless steel refrigerator. Freezing in side all food on bottom and middle shelves. Does not matter what temp it is set on. Sears has replaced first fridge and now second fridge is doing the same. I have had 5 service calls on this fridge and it was diagnosed with a bad sensor, it was replaced and in about 2 weeks problem returned. When I called for service call I was referred to customer service and was told the fridge was out of warranty and there was nothing that they could do for me. This is a faulty model and as far as I am concerned a LEMMON. I don't know where to go at this point for help. Can you help me
  • Steve Allison
    Steve Allison Apr 07, 2011
    Since I don't have any good suggestions for you, I'm posting this only as an FYI- Go to ripoffreport.com and register your problem there, you may get a usable response since some manufacturers monitor such sites and may even try to correct the problem so they can post how they handled it.>>>> http://www.ripoffreport.com/Search/kenmo... <<<<<< Good luck-
  • 66 Answers
SOURCE: Handle to freezer on french door fridge
if the butter fly clip is brroken . you need to change the door. other than that you can replace the handle only. with the butter fly clip. parts cast only 100.00
Posted on Feb 07, 2008
SOURCE: thermostat shows "Err" "FF"
Well, this may be a solution, at least in our case. While were were unpacking the refrigerator and dumping food into coolers, we also unloaded the freezer, even though it appeared to still be running.
After clearing it out, we noticed that the icemaker device in the upper left corner was all iced up, like an old freezer does without self-defrosting. We thought our machine was a self-defroster and this made us suspicious.
We unplugged the appliance and defrosted this upside-down iceberg in the freezer. After it was cleared out, we plugged it back and and lo and behold, the thermostat came on! Here it is 12 hours later and it is still running.
So, it may not be the actual cause, but I can't come up with another solution at the moment. By the way, it makes us wonder if the error code "FF" that we had stood for "freezer fan". Perhaps that iceflow interrupted the fan or its circulation, somehow? In any event, other people with this same error code (FF) might check for icing forming around the icemaker.
Posted on Jul 06, 2008
SOURCE: Interior Lights "ON" With Doors Closed
Jane0901. Go to the following web site. Look at the solution section concerning Sears Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}Service flash "sf46-515". I am "DaleCos" and have the same problem. I have reported the probem to Consumer Reports and the Consumer Product Safety Commission. More people need to contact these two organizations. Good luck.
http://www.fixya.com/support/t968825-interior_lights_doors_closed
Posted on Sep 05, 2008
  • 32 Answers
SOURCE: LG LFX25960ST Stainless Steel French
Contact your parts supplier, this is a replaceable part
Posted on Dec 23, 2008
  • 145 Answers
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
Posted on Jun 07, 2009
Food freezing
Hi Susan,
I had the same problem with food freezing on the bottom of the compartment, especially the veggies. I had set the thermostat to 34 for cold beer but I guess the thermostat is off a bit. I put a thermometer on the bottom shelf to make sure that I had control of the temp and set my thermostat until it was 36 inside. The thermostat on the front reads 40. I guess that 38 might be the magic number for you.
Jun 18, 2014 | Whirlpool GI5FSAXVY Stainless Steel ...
Neither the refrigerator or freezer temperature controls work. Can't adjust them and food is freezing in the refrigerator.
Sounds as though the thermostats have both gone. Before you replace them remove the mains plug. Fridge is easier than the freezer. The wire on the freezer runs under the top shelf usually. Good luck
Nov 24, 2013 | Whirlpool GI5FSAXVY Stainless Steel ...
The refridgerator compartment is freezing all the food
What is the complete model number list in the refrigerator section?
Oct 11, 2013 | Samsung RFG299AARS Stainless Steel (285 cu...
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
The fridge is freezing my milk, lettuce and fruit. The temp was set at the recommended 38 degrees. What do you recommend?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 09, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Our Whirlpool GI5FSAXVY refrigerator is freezing items. The temp control has been set to 38 degrees forever. It appears that things on the lower shelves are freezing more than things on the upper...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
GE GFSL6KEXLS Stainless Steel (2585 cu ft) Bottom Freezer French Door Refrigerator Problem: Freezer handle is all stainless steel is loose. How can I tighten it? I looks like I would have to go through...
look for a small hole on one side of the handle. There should be a set screw there you can tighten. (the handle attaches to a ball shaped peg under the handle, and does not attach from the inside of the door)
Nov 28, 2010 | GE GFSL6KEXLS Stainless Steel (2585 cu ft)...
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
The freezer side not freezing just cool, the
Open freezer door, pull food off shelves on lower half of inside freezer and look if you have frost building up on the back wall of freezer. If you do then you have a defrost heater or thermostat possible gone bad.
Advise if you have frost build up and I will advise on how to check it.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Food is Freezing in the refrigerator
I had removed the bulb in the fridge they seem to heat the temp probe and cause refri. to stay running hope suggestion help toward solution
May 04, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
