Question about Kenmore Washing Machines
Kenmore 80 series Model # 110.23832100\r\nthe washer fills up agitates, when finished washing it stops pauses a while then starts to spin, you can hear the water going out put it is like it can't pick up enough speed to spin all the water out. I can stop and turn on spin and it takes it out. It doesn't take all the water out before it goes into rinse so rinse water doesn't appear clean. When it goes into final spin it doesn't take all the water out so I have to send it into another spin. Then into a second rinse and second spin plus I always have to send into another spin to get all the water out. Please advise.
  • jbartman Apr 10, 2011
    No this doesn't solve the problem. It works some times and other times it doesn't. I have checked all these things so I feel it is either in the timer going bad or the pump going bad. I don't remember how old the washer is and I don't want to put alot of money in it getting it fixed if something else is going to go wrong. Thanks for you help but it is just a guessing game. Plus it costs $100.00 just to have someone come to look at it anymore. We live in this "throw away world". Sealed units just don't let you get in to fix any simple little thing, you have to replace the time or the pump with a whole new part.
    Thanks anyway.
  • 4,323 Answers
Hi
If the washer is not draining then it is due to a clogged drain pump, drain filter or a kinked drain hose. Clean the drain hose, inspect if the drain hose is plugged. Also check the connection to the drain pump and make sure wiring is fine. Check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
  • Daniel Scott
    Daniel Scott Apr 10, 2011
    Please see the video and check that the drain pump is
    working properly. If not then you'll need to replace it---
    Please see the video and check that the drain pump is working properly. If not then you'll need to replace it---
Kenmore 80 series washer, replaced lid switch already, will fill, wash (agitate) but stops before draining and spinning and will not run. Is the timer the next step for replacement? Model: 110.29852991
First check the continuity of the wires in the lid switch and the switch itself. Make a jumper wire to attach to the lid switch connector on the washer cabinet and set it to spin. If still no spin,replace the timer.
Aug 14, 2009 | Kenmore Washing Machines
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 80 Washer Won't Spin
Your timer has failed to initiate a pause for the transmission to lock in.
Replace your timer. Solve your problem.
Feb 21, 2009 | Kenmore 22422 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Washing Machines Logo
171 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
