Question about HP Deskjet 1120c InkJet Printer
HP1120C PRINTER. My print image starts off perfect, but for the last 1/3rd of the page the image alignment and clarity deteriorates to such an extent that lines and text are blurred, similar to a paper jam. However the paper is feeding as normal. Any one experienced this issue??
  • brimoeng Apr 07, 2011
    Paper settings have been checked and am using same brand & quality of paper.
    I dont think its a print head problem, as the print is 100% perfect for the first 60% of the sheet, but then the print work becomes blurred, and lines are running off at an angle to an offset of about 14mm.
    If there was an issue with the print head/cartridges i would expect the quality of print to be poor from start to finish.
    What do you think???
    Have tried a few more prints and it now seems to be getting worse earlier in the print but finishes better, al be it in the offset location
  • 4,323 Answers
Hi
Please check that the paper setting is as per the quality of the paper you are using. If not then set it as per the paper quality and test a print. If it still showing the smeared result then most probably the print head needs to be cleaned by running the print head cleaning utility. After the cleaning program is complete, check if the print quality has been improved. If not then the toner cartridges needs to be replaced. Before replacing the toner cartridges please make sure that there is no toner spill in the printer which you can clean out after opening the access doors. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
  • Daniel Scott
    Daniel Scott Apr 07, 2011
    Please follow the procedure as shown in the video--
    Daniel
  • HP Master
  • 3,530 Answers
Welcome to Fixya
Try to reset the printer. Resetting the printer is useful for quickly clearing minor software problems so you can continue working. You should allow approximately five minutes to reset the HP 1120c.
  • 1 Turn off the HP 1120c by pressing the power button.
  • 2 Disconnect the power cord from the back of the printer and unplug it from the wall.
  • 3 Wait for 30 to 60 seconds.
  • 4 Reconnect the power cord to the back of the printer and to the wall.
  • 5 Press the power button to restart the HP 1120c
  • Thank you for using Fixya!
    Dell 3100cn prints the wrong colors
    Go to Control panel
    Click on: Hardware and Sound
    Click on: Devices and Printer
    Click on your printer
    Click on Adjust printing preferences
    Then go to the Maintenance Tab at the top (should be last tab)
    Then click Print a test page
    You can also Align Ink cartridges from here and clean the Ink Cartridges
    If that does not work then update the drivers:
    Go to Start
    Type in box Device Manager
    Click on Device Manager in list
    Wait till list populates.
    Click on Imaging devices
    Right click on the printer
    Update the drivers by searching online
    Apr 03, 2013 | Dell Laser Printer 3100cn PCL6
    My HP 2410 photosmart printer has started to print everything crooked. The paper is going through perfect but the printer left margin starts to increase about half way down the page. At the bottom the...
    probably a simple alignment problem. Go into your maintenance section and there is an option to align . Run this and it should realign your printing. Hope this helps!
    May 09, 2011 | HP PSC 2410 All-In-One InkJet Printer
    I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
    Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
    Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
    1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
    2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
    3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
    4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
    Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
    1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
    2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
    3. Click the Device Services tab.
    4. Click Align the Print Cartridges .
    5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
    6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
    7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
    8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
    Apr 19, 2011 | HP Office Equipment & Supplies
    Prints one or two lines then you get a scrambled error message and it stops until you press on button then it does the same thing again, I have unplugged everything several times and even uninstalled and...
    Use the HP Toolbox to perform the following tasks:
    • Calibrate the printer to align the print cartridges.
    • Clean the print cartridges when lines and dots are missing from your printout.
    • Print a test page to check for clarity after cleaning or to verify that the printer can receive data and print from the computer correctly.
    • Print a diagnostic page to show how the print cartridge nozzles are working.
    • Calibrate the photo tray to correctly position your photos.
    • Check the ink levels of the print cartridges. Adjust the printer configuration.
    • Investigate warning conditions.
    Opening the HP Toolbox from the printer icon
    1. Double-click the HP Digital Imaging Monitor and make sure you are on the correct printer tab.
    2. Click Settings and then click Print Settings .
    3. Click the Printer Toolbox choice.
    Opening the HP Toolbox from the Printer Properties
    1. Click Start .
    2. Click Settings .
    3. Click Printers .
    4. Right-click the icon of the printer in use.
    5. Click Printing Preferences .
    6. Click the Features tab.
    7. Click the Printer Services button.
    Oct 25, 2010 | HP PSC 2355v All-In-One InkJet Printer
    Printer printing blured images and text. It looks as if the printer prints a line then about 1/8 to 1/16 if an inch it prints the same line again.
    You need to run a new alignment on the machine, Assuming you have the software installed open up the hp help center and print an alignment page after that look at the numbers and letters and line up the marks by selecting the numbers closet to the perfect alignment that you can see after you have finished click on the front of the printers OK button.to finish they try printing a new page. If this does not help try updating your software at http://www.hp.com.
    Dec 24, 2009 | HP PSC 1210 All-In-One InkJet Printer
    Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
    ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
    Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
    Stripes on Images only - Text OK
    Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
    Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
    May 24, 2008 | Canon BubbleJet i560 InkJet Printer
    Well, this is just stupide
    John, here, at Dell headquarters. A few suggestions that may help: First, make sure the printer is not plugged into the front USB ports on the system. Sounds strange, but that sometimes makes a difference. Second, unplug the printer, restart the system, then plug the printer into a different USB port. That may fix the problem as well. Third, uninstall and reinstall the printer software. That could also do the trick. If none of these suggestions work, I'd recommend calling our tech support.
    Apr 16, 2007 | Dell 924 All-in-One InkJet Printer
    HP Deskjet 1120c InkJet Printer Logo
    65 people viewed this question
    Seeker5211
    Seeker5211
