Question about Cst Berger Digital Theodolite 56DGT2
Dgt-20 problem no vertical mesure SET all the time
    Scholar:
  • 87 Answers
So if you were to look at the signals of how this instrument reads it's angles, you can see a vast voltage difference when you pass 90 deg. This is how they 0 set, and start counting from the 90 deg position. What happens is when a electronic component fails, or the unit receives an impact, that voltage difference changes. And the instrument cannot see it's 90 deg point any longer. It is a complicated repair, that involves electronic testing equipment and adjusting/replacing the electronics that produce and read that signal or mechanically adjusting the glass circle that the angles are read from.
Most technicians i know (myself included) cringe at this repair, and it is not something that can be completed at home. In a lot of cases, due to the price of these instruments, and the lack of economical parts, this error can be a wite off for the theodolite.
Posted on Dec 13, 2014
  • 710 Answers
Hi Nico,
I can't find any help on this online, however, I did find a toll free number for Cst/Berger, tech support. Here it is: 1-800-435-1859
They are available only from 9-5
I hope this helps. If it did, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 09, 2011
Craftsman dgt 4000
Broken gear at the end of the steering linkage, or broken teeth, also check to see if the stationary gear mounted to the tractor itself isn't broken off or worn out.
Jun 08, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Which instruments does the the CST/berger DTEP diagonal eyepiece work with?
according to http://www.engineersupply.com The CST/berger DTEP diagonal eyepiece works with the following instruments:
  • CST/berger DGT-02 theodolite (56-DGT2)
  • CST/berger DGT-10 theodolite (56-DGT10)
  • David White DWT-10 theodolite (46-8890)
Apr 17, 2013 | Retail Supplies
I have a dgt. 6000 27hp 48cut red
hello, what is your problem with your DGT 6000 27HP 48"cut red and what is it???
Feb 19, 2012 | Craftsman Garden
Hi = My LG5010 has developed vertical lines on the right hand side - if I move the screen backwards and forwards, the lines go away, but as soon the TV is switched off and on again, the lines come back. ...
The problem is most definately the LVDS cable that goes from the Main board to the Tcon board. The main board is the large one in the middle of the set and the t-con board is at the top- middle of the set. The connector is a long skinny plug with usually 20-25 pins. The connector can be unpluged (carefully) and cleaned with alcohol and a q-tip. There is NO VERTICAL Chip in any LCD or Plasma sets. Vertical circuits of that design have been gone since the inception of DLP, LCD and Plasma sets. The last analog set rolled off the line in 2005.
Sep 25, 2011 | LG 42LC2D 42 in. LCD HDTV
I need parts list
spec for belting - size and mesurement
Jul 11, 2010 | SaniServ 401 20 Quart Ice Cream Maker
AFTER CAR REACHES RUNNING TEMP. IF YOU SHUT CAR OFF AND LET IT SIT FOR 15- 20 MIN. IT CRANKS OVER A LONG TIME BEFORE STARTING
The BMW have divices to mesure the temperature check the cooland that you using and the oil of the car, also check if the car temperature goes up fast when you turn on the car.
Feb 02, 2010 | 2003 BMW 325
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
Pink (Magenta)vertical line appears on the screen
Vertical magenta lines could be a symptom of a loose connection to the optical assembly,or a source of interference. Try resetting the TV first - unplug from wall socket for about 2 hours, replug, and see if it works.
Also check the cables/connections from your cable box, etc and see if the issue can be resolved by manipulating the wires. Could be a loose connection..
Oct 03, 2008 | Philips Televison & Video
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Cst Berger Digital Theodolite 56DGT2 Logo
158 people viewed this question
Top Cst Berger Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cst Berger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
