Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
I have a pharmore wizard four wheeled scooter in the last year i have used it for one week it is under cover over winter. i put the battery on that was fully charged and i went two hundred yards and it stop and gave five bleeps stopped gave onother five and so on i turned it off and back on again and it repeated the same thing i have left it for 3 hours and tried it again same outcome hope you can help me regards malcolm cooper
Where can i get a spare battery for a pharmore wizzard mobility scooter? also arms thank you jimbopil@live.co.uk
Posted on May 21, 2012
  • 692 Answers
SOURCE: We have a Fortress Scientific 2000 electric
zippidi Check the freewheel lever and make sure you can't push the scooter easily. Turn off the switch and turn back on and try to make sure it moves. Hope this helps you
Posted on Oct 03, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
  • 177 Answers
SOURCE: I have a milan mobility scooter,turn the key & it sounds a low
Hi. This sounds difficult. I have had a few scooters move slowly forward or in reverse, but not both. Normally if the speed pot ( wig wag ) is not exactly in the central position, they can do this.
It is possible for a scooter to have your problem, if the speed lever is binding or rubbing on the housing. Normally the lever is returned to the middle by a spring around the speed pot shaft. If this spring is loose or broken, then this could also cause the problem. Sometimes a small spot of oil or grease will help.
To check the speed lever is in the middle, slowly move the lever for forward untill you hear the brake solenoid release. Now release the lever and slowly pull it for reverse untill you hear the brake solenoid release. Make sure that the speed lever moves the same amount for forward as it does for reverse. If not adjust it with the key off.
If you get the machine to drive properly, then change the controller to see if it is OK.
As for the beeping, a lot of machines will go into an error mode if the speed lever is not in the central position when you turn the key on. This is a safety precausion.
Good luck. Neil.
Posted on Jun 07, 2010
Testimonial: "hello,thanks for ur info.i came to be here by paying for it,then ended up answering questions for others,my scooter is still not working.its a long story but i have learned a lot & have lived my life helping others.i recently downloaded info from shoprider,not having my scooter has depressed me like you wouldnt believe,but i will eventually get it sorted,this is my email if you wish to exchange info,i was punched off my scooter last year & suffered concusion.hence i have a problem getting to grip with things at times.the CPS dropped the charges against the young male 150 people there i had it put in local paper for witnesses with no help lol.gotta laugh whats the point moaning colintaylor1957@hotmail.co.uk"
  • 177 Answers
SOURCE: Scooter stops intermittenly
Hi. Does the machine stop suddenly, or does it slowly stop as it normally would? Does this happen on hills or slopes?
A lot of scooters have a self-resetting circuit breaker connected to the battery leads. If the machine draws to much current ( amps ) then the circuit breaker trips out. After a few minutes the circuit breaker will reset and you can continue.
This could mean that the circuit breaker is faulty or that the motor is drawing to much current, or is burnt out.
Some machines have a very light duty circuit breaker, and these can trip out often. I have changed many of these circuit breakers for this reason.
Check all your battery leads are secure and tight.
If it is still a problem, get a serviceman to check the motor current is what it should be.
Good luck. Neil.
Are 12 AH batteries correct for a Wizard4 German Scooter?
hi please confirm by looking at the pictures what one your scooter is
Wizard 2 Folding Mobility Scooter Silver Self Assembly
Pharmore Mobility
if so they are 12v 12ah batteries...
Regards
Rob
Sep 28, 2016 | Health & Beauty
Batteries for a 4 wheeled mobility (German Wizard) Scooter bought from Pharmore mobility ltd? They no longer deal with mobility!
Just remove one of the bad batteries and take it to any battery place and they will have for you an equivalent to do the job.
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
My pharmore wizard diagnostic light flashes 9 times and my scooter does not go, can someone help me please
possible brake issue or controller issues. Depends what make controller is on board, PG or Dynamics?
Oct 08, 2014 | Health & Beauty
Razor e200
Hi, check all the connections are clean. It could be the charger is done but some batteries when they get left for a long period without charge they won't take a charge any more. Disconnect from power supply before attempting any inspection. Check the wheels are turning freely and not binding. Then last of all the motor may have to be checked.
Apr 21, 2014 | Toys
My Battery on my Shoprider Delux is fully charged but lasts only about 45mins is my Battery Knackered?
first of all , this is a common mistake , can you borrow another charger to make sure that is not causing the problem , you need to convince yourself that the charger is okay then lok at the batteries located under the cover located under the seat, make sure the batterys connectors are clean and tight, if all fails sadly it is a batteries replacement.
Nov 21, 2012 | Shoprider Sprinter Deluxe Four Wheel...
If not using a scooter for months at a time, what is best way to preserve the batteries and the scooter?
There is really no easy answer for this, it's kind of a lesser of 2 evils kind of thing.
The batteries on scooters and power chairs have a gel inside them that will oxidize or solidify if it is not put on a charger on a regular basis (at least once a week for 8 hours). However, keeping the batteries connected to the charger for a long period of time (weeks, months) can cause the power cells inside them to deteriorate and not last as long. Scooters and powerchairs are meant to be used and portable, which is why this type of universal gel battery is standard in nearly all of them.
Storing the scooter outside can be a problem as the controller can be damaged by water, heat or condensation and the tires and seat upholstery may crack under weather extremes as well. Storing inside is recommended, if possible.
The best I can suggest is to store the scooter in some type of shed so that it is protected from the elements, and cover it with a soft water proof cover, like those used to cover outdoor grills. Get an outdoor electronic light timer and drop cord and plug it into a grounded outlet, attach the charger and plug the scooter to the charger. Set the timer to turn the charger on for 8 hours once a week. Hopefully, this will keep your scooter in good condition until you can use it again.
I hope this information is helpful to you- good luck!
Dec 27, 2010 | Electric Mobility 3 Wheel Motorized...
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
1,506 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
