Question about Vacuums
One control of our Westpoint bed warmer is flashing. I checked the wall plug and it seemed ok. May this be a sign for a power surge problem.
    Problem Solver:
  • 6 Answers
Sounds more like a damaged wire in the half of the bed that uses the flashing controller. Recommend replacement.
Posted on Apr 09, 2011
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
Jul 07, 2017 | Kirby Vacuums
Dyson DC 25 wont turn on
Why does your daughter think that? While a whole house surge protector is something I can't recommend enough, it's highly unlikely that the average power surge would take out a vacuum. The usual suspects are not plugged in all the way, the filter has never been cleaned, the cord has a tweak, break or is exposed somewhere or the vacuum's fuse blew (if it was a power surge, that's where you'd want to look.
Your owner's manual should have instructions for changing the fuse, if not, take it to a certified Dyson service store and have them check the fuse for you. :)
Jul 05, 2016 | Dyson Vacuums
Why is my eureka super broom not turning on?
When machine does not work, first check wall outlet ( plug in an hair dryer or table lamp to check wall outlet. ) and it that is OK than check your power cord for break ( if wire's are broken inside outer coating the cord will be very weak at that point )
May 15, 2014 | Eureka Super Broom 286 Vacuum
Our westpoint home electric blanket, model 950, flashes 8 on one unit & can't be turned off. ELECTRIC BLANKET!!
Try pressing the power button and boost button at the same time. Then a C will flash and the setting you had it on before will show up. I think that was caused by pressing the boost button.
Dec 28, 2010 | Vacuums
I received this electric blanket as a gift and it will not heat up on either side. There is no light on the controls when I turn the blanket on. I need my blanket to work - it's like brand new!
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
Sep 18, 2010 | Sunbeam Vacuums
The power on my cuisinart microwave is coming on, but I cannot get the other controls to come on. The microwave is not even two years old, and is hardly used.
If there is no responce on 2 or more buttons, the board is certainly in need of replacement. Normally one button indicates the toutchpad. Need to put on a surge plug to remove unstable voltages.(In S.Africa, we call the protection plugs "surge plugs").
Aug 03, 2010 | Vacuums
We have an sunbeam electric blanket model BL 0750 We dont seem to be able to programme it to heat up. Control lights are flashing
Hi. If you have a double or queen size blanket, switch the controls from one side to the other. If the fault follows the control, then the control is faulty. If the fault stays on the same side of the bed, then the blanket may be faulty. Most recent Sunbeam models have 3 years warranty. Once you've checked the controls, if it's under warranty call Sunbeam Customer Service on 1800025059 option 1 to report a warranty issue.
Otherwise: if the control is at fault, a new BL0750 has a recommended retail of $75.20. Get in contact with your local Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
but if all else fails email me as I'm happy to help!
May 25, 2010 | Vacuums
Miele Blue Moon vacuum has no power
It can be various problems, the cord reel contacts or cord may be bad, You didn't give the model number, but alot of Miele's have a speed control that goes bad. It will have to taken aprt and checked.
Jan 31, 2008 | Miele Blue Moon Bagged Canister Vacuum
DYSON DC05
My friends Dyson DC05 was loosing suction and then it stopped altogether one day. When she took the filters out there was black soot in them so it was obvious that the motor had burnt out. I think this happened because she wasn't cleaning the filters regularly (go do yours now!) I replaced the motor myself and wrote a guide with photo's at www.tasweb.org
Dec 11, 2007 | Dyson DC05 Cylinder Bagless Canister...
Vacuums Logo
83 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
