Question about Chi Nano Digital Ceramic Flat Iron 1.25 inch Farouk Hair Straightener, 44 Iron Guard, Silk Infusion, Heatproof Storage Bag Mat
Hi. I am trying to locate where I caan get my chi nano flatiron fixed. My iron has a short in the cord. I have contacted the manufacturer and they can't fix it because it has been more than one year since I purchased it. If u have any info where I can call to have it fixed, its greatly appreciated. My email is Nicoleroseg@gmail.com. thank u! -nicole
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
Nicole,
You should look at www.flatironrepairs.com. That should be repairable.
Posted on Feb 21, 2013
3 Suggested Answers
tomslick65
  • 4 Answers
SOURCE: Just bought it online and
Sorry Jason but they are not machine pressed. Remove the round "Chi" Logo covers at the hinge , underneath you will see 2 large phillip type screw heads.Take 2 large phillips screwdrivers, grip firmly and twist (lefty loosey) and with a bit of effort you will loosen them. NOTE: Put a rubberband or something at the open end BEFORE this to prevent the spring for doing what springs do when you remove the pin at the hinge. The pin is male/female type with one long side with a machined exterior and internal threads and a shorter bolt or screw side with traditional external circumferential threads. Once this is out and you take off your rubber band safety you can carefully remove the hinge spring. Note that one side of the spring is longer and that side goes on the longer half of the iron which should be the half with the switch. All the main business is on the swith half, so remove the four screws on cover plate (2) at top just below ceramic and (2) just above the hinge area. You may have to pry this apart but it shoud remove hinge end first then top. Remember to install it in reverse as it was removed. You will see a circuit board and (4) wires at the top. The inner 2 are for the heating element and the outer 2 for the thermal fuse. Get a multimeter and put it on the Continuity Check mode or Ohm mode. Touch one lead to one outer wire and one lead to the other outer wire. If the meter reads 0, the thermal fuse is open or burned up and it needs replaced before it will heat again. I posted my repair and replacement of a thermal fuse today on here. I did it for about 10 bucks! Hope this helps.
Posted on Sep 28, 2011
SOURCE: I have several "Chi" Flat irons that no longer
Units such as these are heated by "heating element". The elements can only stand so much abuse (electricty) and go bad. If you can find someone who deals in electronics, and is willing to replace it - however, you may end up spending more doing that than if you just replace the entire unit. Research some repair shops (try tv, vcr, dvd repair services) as they may be able to do this, or refer you to someone who does. Thank you for choosing Fixya.com
carsandcomps
Posted on Oct 01, 2011
My chi flat iron is not working
Try resetting it. Sometimes that can fix the problem. Make sure it's not a damaged cord. If it is, let me know and I can help you out with it. If it's not that, depending on how long you've had it, you can probably return it for another one.
Jun 01, 2011 | Chi Ceramic 1 inch Flat Iron GF1001USA
Where can I get a chi flatiron fixed in the Nashville, TN area? One of the ceramic plates broke lose.
I don't know about in Nashville, but you can send it in to www.flatironrepairs.com. Should be fixable.
Feb 06, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
My CHI straightener has a GFI plug that needs replaced.
look up leviton 16592 on amazon or something similar. I just had to replace this on a sedu iron. About $20, but cheaper than a new iron.
41x1vrxnoql._sl500_sl135_.jpgtransparent-pixel._v192551059_.gif Leviton 16592
Jan 23, 2011 | Chi Nano Digital Ceramic Flat Iron 1.25...
Where can I get my Chi Flat Iron fixed. I only used it 3 times but had the iron over a year because I have my hair ironed at the beauty shop due to its length. I bought the Chi to do touchups and am...
Chi Flatiron Repair Fix it Yourself User Photos
Most appliances come with manuals that give you company contact information. My guess is the iron is out of warranty. As irons have high voltage components, do it yourself is not advised. Staying alive is better than fixing an iron. That said, the above link even tells you how to take it apart. I have a hunch that good parts would have to come from another broken Chi iron. And where would you get that! Maybe someone on the above link can be contacted. Alas, you simply wanted a reliable business that might check this out. I doubt you want to pay a technician for his time in taking this apart. I wish you well.
Jun 04, 2017 | Chi Nano Digital Ceramic Flat Iron 1.25...
Defective power cord on CHI GF1001 flat iron straightener
My wife's flat iron had an issue with losing power while moving the iron around. I at first thought it was a cord issue, but before tearing into the cord, I disassembled her iron by popping off the two "CHI" covers from either side of the fulcrum. This revealed a screw which when taken out allows you to push the pin out releasing the handle's spring mechanism. Once opened, you can see the power-swivel thing-a-ma-jig and I saw the positive (red) wire had come off of the little flat board mounted on the swivel piece. I simply re-soldered the wire back on to the flat board and BAM! Good as new!
Jan 26, 2009 | Oster 76076-010 Hair Trimmer
CHI Flat Iron GF-1001
Hello alexkuzin, searching for tech info of the Farouk CHI GF-1001 flat iron is slim to none. The HT-1
is the high side of the 120v and COM-1 is neutral. The TNR will be the thermal resistor for temp regulation. If your 'burned element' is broken anywhere but at the terminal "sorry charlie" you are SOL. The TNR is in series with the heating element and if this is 'burned element" finding a replacement will be difficult. Contact your local appliance/electronics parts store. Oh,how did you insert a 120v plug in to a 220v outlet?
Nov 08, 2008 | Health & Beauty
Chi Nano Digital Ceramic Flat Iron 1.25 inch Farouk Hair Straightener, 44 Iron Guard, Silk Infusion, Heatproof Storage Bag Mat Logo
117 people viewed this question
Top Chi Health & Beauty Experts
ray gallant
Don A
Don A
Are you a Chi Health and Beauty Expert? Answer questions, earn points and help others
