Question about Brother GX-6750 Typewriter
How do you remove and replace my out cartridge? I have never removed a typewriter cartridge.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support you will find down loadable manuals there.
DickyO
Posted on Apr 07, 2011
How do I install the 22210 Correction tape on Wordsmith 250 Smith Corona typewriter
lift the top remove the black ribbon then you can see the lift off tape it should lift up then install the new cartridge.
Oct 16, 2014 | Smith Corona Office Equipment & Supplies
Brothers ax
Turn off the typewriter, open the top-cover and inspect the area around the carrier for any damage or foreign objects.
2. Move the carrier towards the center of the machine.
a. When moving the carrier manually, it should be difficult to move, butit will move under steady pressure.
b. If the carrier moves freely, the drive mechanism may not be connectedproperly.
3. Remove the ribbon and inspect the cartridge for damage. Turn the colored knob on the left side of the cartridge to remove any slack from the ribbon.
4. Check the correction tape to insure that it has not become tangled ordamaged.
5. Close the top-cover and restore power to the machine.
If the problem persists, your machine may require service.
Dec 12, 2013 | Brother EM-430 Typewriter
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I changed the new ink cartridges, but it doesn't work,
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Dec 22, 2009 | Brother SX-4000 Typewriter
Removing the cover
Click on the link below and go to page 41 , that will tell you how to do it
http://www.manualnguide.com/dl/11876/
Jun 16, 2009 | Brother ML-300 Typewriter
The roller spins freely on my brother sx-4000 typewriter
Did you recently remove the daisy wheel cartridge? If you did... did you remember to slide the lever on the right hand side do the cartridge carrier back into its original position to lock the cassetted daisy wheel in place? Remember...make sure to press the lever firmly.
Close the top cover.
Press [CODE] + [RESET] at the same time to moe hte carrier to the previous position.
Apr 04, 2009 | Brother SX-4000 Typewriter
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM Selectric used ribbon won't wind into spool
The ribbon sometime gets wrapped around the ribbon driver,One lever on the right side only releases the lift off tape for removal the other is for ribbon removal, also check that the ribbon is on the outside of the ribbon tensioner where the ribbon exits the cartridge on the left side ( a wire thing with a plastic tube on it.
Jan 29, 2008 | Lexmark Wheelwriter 15 Series II...
Correction Tape
Is the ink cartridge correctable ( yellow or orange core) not nultistrike (blue core) ?
Aug 29, 2007 | Brother EM-530 Typewriter
Brother GX-6750 Typewriter Logo
42 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
