Question about Ricoh Office Equipment & Supplies
Ricoh service code 440-02 mean - Ricoh Office Equipment & Supplies
  • santosj27
    santosj27 Apr 07, 2011
    What model??? That is very importante
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
This problem means yo have heavy load in your main motor mechanism when yo touch main motor when rolling it's stopped replace it and try
Posted on Apr 08, 2011
My ricoh printer stoped printing and came up with an error code sc440-00
The Ricoh copier error code 440 / SC440 is a main motor lock error code.
If you are receiving this error it can mean:
Your Drive mechanism is overloaded
Your Motor driver board is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Aug 28, 2016 | Ricoh Office Equipment & Supplies
Turn main power switch off then on.If error reoccurs.call service.Functional problems. What does mean.
It means that something with the functionality of your device is not working properly. Take it for service.
Mar 07, 2016 | Ricoh Aficio 1018D Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Ricoh aficio service code sc571
solution found on copytechnet.com
sc571 on this machine means fuser oil overflow.
check the oil out sensor connector.
use sp5 810 to reset this and most other codes.
Apr 02, 2011 | Office Equipment & Supplies
Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Jan 11, 2011 | Ricoh Aficio 450 Copier
What does a red wrench mean on the display of a ricoh aficio 2238c?
It means "Service Call Condition", that you have to call a technichan depending on the error code.
Oct 17, 2010 | Ricoh Office Equipment & Supplies
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Ricoh Fax 3800L Error code
You cannot purchase one unless you are a Ricoh certified tec and have a Ricoh ID, or an authorized deal. Why are you asking about the LASER UNIT!
Apr 04, 2009 | Gestetner Copier
Multifunction machine doesn't work
I think you mean "SC550"....all codes are 3 digits. If this is correct, it mean that the Fuser web has expired, and needs replacement, then and only then can the code be reset in service Mode. Call a tech.
Mar 12, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
60 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
