Question about Get Organized BED GUARD RAIL
Looking for an instruction manual for a babydan sleep n safe bed rail. Can you help?
Does anyone know where i can find the instruction manual for my crib model #343-8420-0018?
Found this :
Can you help with this Cribs Cradles Bassinets question posted on FixYa
  1. Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
  2. Lower the mattress to the lowest setting.
  3. Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
  4. You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
If this doesn't help you can try contacting the store you bought it from.
Apr 11, 2014 | JCPenney All-in-One Nursery Crib
Babydan fitting instructions
To be able to log into Babydan media database, you need to have user access: LOGIN
I hope this helps.
Oct 02, 2010 | Toys
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Wood Rails Needed for Simplicity Ellis 4-1 Bed.
try babylox.com and use the search tool in the website!!
May 12, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Simplicity bed rails to convert to full size bed
we are having the same problem. My husband found this number online that another user said she used. I guess it took her months to find it because with the company being out of business the 800 number that came with the crib isn't working. I've yet to call he just called me with it. the company is out of canada and is said to have the rails or able to get the rails. Its Else Graco, you need your model number and color. 1800-667-8184.
Jan 18, 2010 | Simplicity for Children Ellis 4 in 1 Sleep...
Can't find the manual to convert the 4 in 1 to a regular bed
Yes you need the rails. I have the rails - I bought the wrong ones for my crib- so these would help you.
Jun 22, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Get Organized BED GUARD RAIL Logo
235 people viewed this question
Top Get Organized Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Get Organized Baby Gear Expert? Answer questions, earn points and help others
