Question about Maytag MDE9700AYM Electric Dryer
Hello I have a maytag dryer bought in 2001 model #MDE5500AYW until now no problems now after running 5 min it shuts off it starts right up but turns off again I cleaned the back of the dryer and checked the vent but it still happens also IF I hold the sensor dry button in it doesnt happen thanks in advance for your help
  • 4,323 Answers
Hi
I believe that everything else is fine rather it is the thermostat that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if bad replace it as it cannot be reset. If the fuse is fine then check the dryer belt and idler pulley...Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 07, 2011
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Maytag dyer problems
it sounds like the control board is going bad but i wouldn't buy any parts for this dryer,soon you won't be able to get parts for it,put the money into a new dryer not to mention that the neptune products is what took maytag out and now whirlpool owns maytag.you could also have a problem with one of the connections or a bad wire in one of the connections and when you move the wires it's working again and this could be from the heat,after years the wires get brittle,you could buy the new board,put it in and if it's a wire you're back to square one,but from what you say it's either a wire in one of the connections or the board.good luck with your dryer.
Nov 12, 2013 | Maytag MDE5500AYW Electric Dryer
It shut off and now it wont turn back on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Maytag MDE5500AYW Electric Dryer
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag dryer model number MDE5500AYW has lights on, but won't switch settings. It is stuck in time dry at 18 minutes. Yesterday it was on sensor dry 47 minutes. Do I need a new control board inside...
OK, your control board and LED are integrated, so you will need to just replace the control board. I would try a hard reset before replacing the board. Pull the plug or, shut down the appropriate breaker switch for 5 minutes. Re apply power after the 5 minutes are up. if you continue to experience this fault, replace the control board asap.
CONTROL PANEL(CLICK HERE TO ORDER)
Aug 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
MODEL GE/GQ9858J dryer runs about 5 min. or
dryer was working with codes for 5 to 10 min now there is no heat at all but will stay running?
Aug 02, 2009 | Whirlpool Dryers
Dryer shuts down within 5 mins of running
your vent is plugged up move dryer away from wall and allow room for vent
Mar 25, 2009 | Whirlpool Dryers
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag MDE9700AYM Electric Dryer Logo
41 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
