Question about Panasonic TC-P50X1 50 in. Plasma HDTV
The HDMI inputs on my tc-p50x1 will not work at all. Both component inputs work, but all three of the HDMI seem to get no signal. Is there a fuse I can replace, or do I have to replace the entire mainboard. I tried getting new HDMI cables, but no luck. Have reset the entire tv to defaults with holding the vol button on the tv down for 5 sec. and pressing the menu button on the remote to get into a self-diagnostic mode. I was wondering if there was some way to turn on and off the HDMI inputs. Any suggestions?
  • Panasonic Master
  • 8,457 Answers
No,the HDMI connections hubs are just a few small components parts that was put on by the wave soldering machine and it is on and surface mounted by soldering fussion to the tv to main tv Tuner signal board and funsction as one board,can't replaces these HDMI hubs by itself,it very hard and almost imposible to do so by hand soldering equipments and these HDMI components hubs they don't sell out as individual consumer parts any way.Tries tv unplug,replug it back like about and hour later for the tv to do a resetting itself back to the factory setting.Than go to the tv menu go to PICTURE setting go down to do a resetting to do a resetting to all the funsctions of the tv Tuner signal board.Now all ur HDMI hubs should be working again.If not,the whole Tv Tuner signal board mut be reolaced.Try website like Ebay.com to buy a whole refurbish main tv Tuner signal board for the replacement.
Posted on Apr 07, 2011
Testimonial: "Great!! Thank you for the info and getting back to me so soon."
Panasonic TC-P50X1 don't come on, red light blinks 9 times what is the problem
1) try doing a RESET.
2) if that does not work. with most flat TV today. There three circuit boards - an input, a power and a video. Usually, it is the power supply and specifically, the capacitor(s) that goes wrong. It has high voltage (400 volts) but low current.. Replace this capacitor or could be capacitors.
Oct 26, 2017 | Panasonic Televison & Video
How can I connect my PC to Panasonic viera tc-p50x1
OK, I have no idea if you want to connect a laptop or a desktop, but either way, I'll try to make as simple as possible.
I believe your tv model is not a smart tv. I own one. To connect any external device to the tv, you must set up the external device, not the tv. In this case is a PC, your PC must be equip with an HDMI output, just like a BluRay or mobile device. If it's a laptop, you need to find out which hotkey combination to use to enable the mirroring of your laptop. You can find that out by reading the owner's manual or visiting your laptop's manufacturer website.
If it's a desktop, all you need is an HDMI video or graphic card.
Then just connect the HDMI cable to any of the HDMI input in the TV. Now, with the RC, press source or input to the connected HDMI slot from the TV, in this case there are 3 of them, you must choose HDMI 1, 2 or 3.
Oct 08, 2016 | Panasonic Tc-P50x1 50inch Class Viera X1...
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
I have a Panasonic TC-P50X1 and want to connect my laptop to it. What should I do?
If your laptop has a DVI or HDMI output, then the solution is as easy as buying a DVI to HDMI cable, or simply an HDMI cable, because your TV set uses HDMI as an input. If you have a Macbook, there are Displayport to HDMI cables/adapters available.
However, if your laptop only has VGA output, then you must buy a converter. Why? The VGA output available on almost any laptop is an analog signal. Buying simple cable adapters will not make your TV (which reads only digital signals) read the analog VGA signal.
Oct 03, 2010 | Panasonic Computers & Internet
I have an ILO 32HD and the HDMI input does not seem to work.. goes from no signal to HDMI 10801 but i get a flash of a picture somtimes.. My first HD and can't see it!!! I have tried 2 NEW HDMI cables...
HDMI issues are almost always the scource and not the TV. If HDMI fails to work then use the component inputs as your picture will still be in high definition when on HD channels..
Nov 11, 2009 | Televison & Video
Cc box
Open the menu, then go to setup, there should be a closed caption options in there, also remember that CC can only be passed via a transmitted cable signal. If you have a Cable box or Satellite box connected via HDMI, or its pushing a HD signal (720p, 480p) the CC box is from the Sat or Cable box, test the settings on the box.
Sep 22, 2009 | Panasonic Viera TH-42PX80U Plasma TV
I need to know how to hook up my stereo system to my panasonic tc-p50x1 tv
the audio output on the back of the set goes to the audio inputs on the stereo.
depending on age it may have aux,cd,tape,vcr,video inputs.
they will all work,as they are made for a 300mv to 1 v signal.
the one that will get overdriven severely is the phono input,never use that one except for a turntable.it is made for a 3 to 5mv signal.
a moving coil input is even more sensitive, about.1/2 mv.
Sep 10, 2009 | Panasonic TC-P50X1 50 in. Plasma HDTV
Need owners manual
http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/model.TC-P50X1
Apr 25, 2009 | Panasonic TC-P50X1 50 in. Plasma HDTV
Unable to play DTS-HD & True-HD
What do you hear? Do all other modes work ok?
If Audio Select (Page 44 and 98) is set to HDMI you will hear silence if no HDMI signal is present. I think AUTO is the best choice here.
On Page 98 of the manual it says a bunch of things concerning automatic signal detection and input selection.
Initial configuration D) INIT. CONFIG
Use this feature to select the settings of the audio input jack select, active decoders and extended surround when you tum on this unit.
Audio select AUDIO SELECT
Use this feature to designate the default audio input jack select setting (see page 44) for the input sources connected to the DIGITAL INPUT jacks when you tum on the power of this unit.
HDMI set E)HDMI SET
Use this feature to select the component to play back HDMI audio signals.
Support audio S. Audio
Use this feature to select whether to play back HDMI audio signals on this unit or on another HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = RX-V663
FUNCTION
Plays back HDMI audio signals on this unit. The HDMI audio signals input at the HDMI input jacks of this unit are not output to the HDMI component connected to the HDMI OUT jack on the rear panel of this unit.
CHOICE = OTHER
HDMI component connected to the HDMI OUT jack.
NOTES
This unit transmits audio and video signals input at the HDMI input jacks to the HDMI out jack only when this unit is turned on even if "S.AUDIO" is set to "OTHER".
I'd look in these areas for specific guidance.
Apr 22, 2009 | Yamaha RX-V663 Receiver
Panasonic TC-P50X1 50 in. Plasma HDTV Logo
1,140 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
