I NEED TO RESET THE DRUM UNIT ON TOSHIBA E STUDIO 120
4 Suggested Answers
  • 190 Answers
SOURCE: need driver for toshiba e-studion 120
Dear customer,
                Please try the following links  http://www.copiers.toshiba.com/support/controllers/e-studio120.shtml
http://driverscollection.com/?H=e-STUDIO120&By=Toshiba
Please rate this solution.. Thank You..
Posted on May 03, 2009
taran_2005
  • 10515 Answers
SOURCE: On a Toshiba e studio
The procedure is explained below :-
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]"000""000" will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] "000""000" will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY'S PAPER SIZE SETTING
Follow these steps to change a tray's paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2010
sodeep
  • 3267 Answers
SOURCE: How to reset maintenance drum
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Posted on Jun 27, 2011
Thoshiba e studio 120. What does error code H4 mean?
The Code H-4 Mean the copier needs to be reset. Also I have added a link to help you troubleshoot the copier.
Thread Toshiba studio 120 with error code H4
Mar 17, 2016 | Office Equipment & Supplies
When I get the warning for the drum reset on our 170F do I need to replace it right away or should I wait til it stops working? If I wait how long will it usually be?
This is an advance reminder for you to order a new drum, you do not have to replace it until it asks to do so. A drum unit is rated for 20,000 pages (5% coverage), it depends on your usage, if there lots of graphics of dark color, you have to replace it before it expires. You can reset it, if there is no quality issues. Procedures:
[x]-key to press, {{ Display on the LCD}}
[Menu], [5], {{5 Default setting}};
[2], {{2 Scanner & Printer}};
[0], [4], {{04 Reset drum counter, 1=Yes, 2=No}};
[1] {{Reset Drum Counter, are you sure?}};
FYI: I would recommend that you put a label "Drum reset" on the drum unit, remind yourself, that you must replace it, once you have a quality issue.
Nov 01, 2013 | Toshiba e-Studio DP170F Plain Paper Laser...
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
The error indicator is staying lit constantly on Toshiba e-studio
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
Feb 28, 2010 | Toshiba e-Studio162D Copier
I have a Toshiba E_studio 120 the code is L1
L1-00 indicates scanner unit feed trouble.
U need to perform following checking:
1. Check release of the headlock switch
2. Check scanner unit operation using SIM 1-01
3. Check the drive belt is properly applied to the scanner unit
Sep 23, 2009 | Toshiba E-Studio 161 Copier
Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
Sep 08, 2009 | Toshiba Office Equipment & Supplies
Toshiba e-Studio 232 is showing error message CF60 after I resetted system after a problem How can I remove the error message CF60? Please help.
CF60 indicates Recycle Toner Transport area lock. U need to take out the process unit, remove developer unit, remove drum, drum blade & recovery blade, disposed all waste toner, make sure the gear can turn properly. Then reassembly back everything.
Jun 06, 2009 | Toshiba e-Studio 232 Black and White...
COPY IS NOT GOOD....
weast toner is not go properly.or paper jam in drum unit or paper dust clean in drum unit.
Jul 24, 2008 | Toshiba e-Studio163 Copier
300 people viewed this question
jasbo
jasbo
