Question about Hotpoint NWXR473GV Dryer
How do you oil a squeeky dryer? - Hotpoint NWXR473GV Dryer
  • Hotpoint Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Posted on Apr 07, 2011
Dryer makes squeeky noise when drying
What brand is the dryer and is it front load
or regular?
Apr 20, 2014 | Kenmore 800 7982 Dryer
LG dryer model dle3777w. Squeeky dryer. Maybe the dryer rollers can replacement parts be ordered?
Just to be sure, try spraying some WD40 or similar grease on the shaft of the rollers. I noise goes away, place heavier grease or replace the rollers.
Oct 18, 2013 | Dryers
Squeeky dryer
if the squeeks are coming from the tub while turning. it may be the front tub glides. but the dryer will need to come a part to fix them. good-day ! more possible symtoms-- Damaged Drum Wheels, Deteriorating Drum Bearing, Failing Idler Pulley Wheel, Loose Belt.
Mar 08, 2012 | Frigidaire Dryers
Dryer making squeeky sounds
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 14, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer makes a horrible squeaking sound when running. This dryer is about 22 years old.
This can be squeeky rollers that need to be lubed or else your idler pulley is bad.
Aug 03, 2010 | Maytag Dryers
Loud squeeky dryer
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
May 12, 2010 | GE DVLR223 Dryers
Squeeky noise in the back of dryer when running?
heatman101
May 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I have a squeeky maytag dryer that seems to be getting louder. Is there a lubrication that I can apply to a part?
Your problem sounds like drum rollers have is in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer is squeaking while running.
hi..A squeeky dryer is usually a worn belt.It is better
to replace it.once you replace it you wont get that
noise.
try this out..
thank u..
kindly rate my response..
May 09, 2009 | Whirlpool LGB6300 Gas Dryer
Squealing Fisher Paykel Dryer DE05-US2
dryer's have a long belt that runs around the drum. a common culprit is an idler pulley on the belt tensioner. you can take off the front of the dryer and oil it for a temp fix. it will probably need to be replaced
Dec 16, 2008 | Fisher and Paykel DE06 Electric Dryer
Dryers Logo
50 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
