Question about HP Pavilion p6226fb (2536485) PC Desktop
I have an hp pavillion p6226f-b desktop and when I try to turn it on the light starts and then turns off by itself and keeps on doing it repeatedly it would be great if someone can help
    Sergeant:
  • 214 Answers
If that is the power light that means it could be the power supply of the machine is faulty, its not giving enough supply for the whole system to turn on. If that's the Display panel it could be with the cord or the Display itself that having a problem.
Posted on Apr 16, 2011
My hp pavillion a420n keeps shuting off and turning itself on every once and a while. Also othe flash keeps crashing and programs keep failing. Any clue what it may be telling me?????
Hardware failure - the voltage to the processor is unstable because either the PSU or the rectifiers on the motherboard have aged. Open the case and look at the motherboard - if some of the capacitors on it are bloated then you will have either to replace them or the entire board. If the capacitors are fine in there then the fault is in the PSU - you can get a new one for less than $20 at every pc shop.
Jun 03, 2011 | HP Pavilion a420n PC Desktop
Hello, when i turn on my hp pavillion a6010n, it will give me a medium beep then followed by a really long beep, then repeats, Won't start up and monitor won't turn on...
If you start up your PC without any RAM modules installed does it give you the same beep code?
If it does then the PC can't recognize the RAM, this could either be because the RAM module is faulty or it needs to be cleaned, use tissue paper to clean the finger contacts on the RAM modules.
If under warranty then return it, they will sort it out. If not try borrow some know to be working RAM from another computer. If it works then this confirms that your RAM is faulty.
Your timeous rating of this solution is much appreciated. Thumbs up
Thanks
Nov 04, 2010 | HP Pavilion A6010N (882780985575) PC...
My pavillion dv9000 laptop will not boot When I try to turn it on, the power turns on but it turns off by itself and turns on again and repeats it over again. I found out that other people are also having...
dv2000/dv6000/dv9000 recall
I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Mar 03, 2010 | HP Pavilion dv9000z Notebook
HP Pavillion DV 6000. Turned it on and it shuts
Is heatsink connected to this problem? (sic) Most probably not, it is more than likely a simple Driver problem. Try to startup in SAFE MODE, press F8 at boot time. If this works you could run a "System Restore" back to a time before it went faulty. Or troubleshoot from safe desktop.
Feb 10, 2010 | HP Pavilion dv6000z Notebook
HP Slimline Pavillion s3123w monitor going to sleep.
Sounds like the motherboard might be bad but go thru these steps.
Unseat and reseat the memory one stick at a time in each slot one at at time and turn on the computer after each stick reinsertion.
If that doesn't get the video to come back up then go ahead and unseat and reseat the CPU. Then try turning on the computer.
If that doesn't do it, make sure there is no power going to the hard drive or the dvd drive. Then try turning on the computer.
If you do all of these steps and you still have no video, then the motherboard is bad and would need to be replaced.
Aug 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Hello I have a hp pavillion a705w it wont turn on any monitors
How Would I Go About Hooking 2 Monitors Up To My a705w
Jan 18, 2009 | HP Pavilion a705w PC Desktop
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
Hp pavillion s3420f slimeline power light shows green but the switch won't turn the computer on
have you tried taking the battery out and putting it back in again and trying again, if yes take it to a specialist and get them to check the connection on the board itself should be a cheap fix hope this helps
Sep 24, 2008 | Computers & Internet
HP Pavillion a550y
GATEWAY DESKTOP DX4900-09 GREEN POWER LIGHT KEEPS BLINKING, COMPUTER WON'T COME ON.
Mar 02, 2008 | Computers & Internet
HP Pavilion p6226fb (2536485) PC Desktop Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
