Hi help me
My sound setting is not working
  • 2 more comments
  • gunasekaranv Aug 06, 2008
    my laptop model is acer extensa 5602z sound setting is working not properly pls help me
    but do one thing i have sound card drive still installing not properly so pls help me
  • mdgccc Mar 21, 2009
    The laptop does not produce any sound
I format my pc but i lost my computer sond how can i solve this i dont have the mother bord cd
Posted on Sep 27, 2008
  • rafiksa Sep 27, 2008
    please do it fast
  • 781 Answers
It seems like you have no sound driver installed
go to control panel/system/device manager check for any with a yellow mark on them click the small + to expand menu right click driver and upgrade your driver go on the web to find them normally it will find and install them
Posted on Aug 06, 2008
Hi,I have a Lemax Yuletide Express Train set. Worked well first night however on one of trips around the track, the greetings stopped. What should I do to get the sound back. Can anyone help? Thanks
Some of these trains have 2 sets of batteries. One set ran the train, one set runs the sound effects. Perhaps the batteries that make the sound work are bad, or loose, or that system has failed.
God bless your efforts.
Dec 10, 2016 | The Toys
My intex headphone not working in new soundcard
HI deepkul,
The headsets should work regardless of the type of sound card,
I would recommend you to check the head set in some other PC and then you will get a confirmation whether it's working or not, if it's working then it's the problem with your sound card and it's not just a problem with the head set but with the sound output.
Hope this helps ..:)
Jun 16, 2011 | Computers & Internet
CAN'T INSTALL SOUND DRIVER FOR zYREX T14c COZ THERE'S NO SOUND HARDWARE DETECTED
Hi.
First option: Go to bios setting power on your PC then press F2 or DEL if you see bios setting highlight advance setting then search for audio device need enable and press F10 to save and exit.
boot to your operating system, try see device manager for sound hardware detection.if detected just install sound driver.
Second option: if you do first option not yet working sound card. I recommend you purchase USB sound card external.it's very easy to install.
hope can help you.
Jun 13, 2011 | Computers & Internet
Hi, my palm centro has no sound. i.e, no speakerphone, no dial tone, no audio on videos but the alarm works that's it.
Hello rossgreni340,
First, make sure the ringer switch is set to 'ON'. It's the little button on top of the Centro. It's turned on when it's pushed to the left. If that doesn't help then check the Sounds settings. The Palm Centro sounds settings can be accessed and changed from the 'System' screen like this:
•Press the 'Home' button on the Centro.
•Tap the 'System' category (top of sscreen).
•Tap 'Sounds' to change the sound settings as you desire.
I hope this helps to resolve the sound problem.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw152
Jul 29, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Can't work out how to turn on sound for reminders ONLY
Hi. Just tap Settings from Start Menu, then tap Sounds&Notifications, in the second tab, you can change all the settings for your device's sounds and notifications. Hope this helps.
May 13, 2009 | HP iPAQ RX3715 Pocket PC
Sound not working on laptop
Hi there, Depending on operating system but assuming windows.
Start with going to your settings
open your Start menu, Settings, Control panel, Sound and audio devices, If everything checks out then proceed to
Start menu Settings, Control panel, System, Device manager, Hardware, Find your sound card, right click and select update driver. I hope this helps and good luck.
Mar 09, 2009 | Acer Computers & Internet
One sound channel not working on an assembled, IBM type machine
This sounds like the cabling from your computer to the Creative amplifier is at fault. Try replacing the cable(s).
Jan 17, 2009 | Computers & Internet
No sound when plugging headphone
Go to the control panel and then open system.
In there you should see your hardware. Make sure it is all set correctly.
Also check the speaker on the taskbar. Open the sound and make sure that all are checked or (not checked) on to make the sound work ... wave, midi, and so on for what you are playing . Some will turn on when checked, some will turn off when checked...try these settings.
Make sure your music player is set correctly. Go to the properties in the program.
Aug 31, 2008 | ASUS P5VD2-MX SE Motherboard
Microphone will not work
have you made sure all the settings are right in the onboard sound setting?
Dec 19, 2007 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
