Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
How to change the filter on a 34700z - Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
    President:
  • 180 Answers
Swithc on the machine & first press the MAIN MENU key,then keep pressing UP or DOWN arrow key till scree show "CHANGE FILTER" option. Then press "YES" key & now just follow the on screen message(Do not skip any option while active "CHANGE FILTER'').
Filter located on back side of the machine & fixed with the manifold assy.it's long black color & you may see the sticker with part no# 34724 (spin-on filter dyer).
Hope this will help you.
Posted on Apr 08, 2011
  • 1 more comment
  • Mario Pasana
    Mario Pasana May 04, 2011
    the serial number error displayed after changing new filter drier, and i read in the manuals that if these displayed comes on either this number is invalid or the filter drier has been used.. i called the technician of these machine where we bought it.. he said i fixed the filter wrong... what can you say about this huh? coz i got an angry feeling of what technician replied.. i think its just an easy to fix for the filter ... My decission is to buy again for a new filter to another company (not in the company where we bought this machine)...please comment
  • Hasan Khan Amran
    Hasan Khan Amran May 04, 2011
    If your machine is Robinair,Model:34700Z then it will never aske for any code or serial number while filter change!!! My above post only for Model:34700Z. However you don't have to buy a new filter, i think your machine is Model:34788 or 34788-I, if it is then just apply this code: FD37FE3601. i am 100% sure this code will solve your problem
  • Mario Pasana
    Mario Pasana May 05, 2011
    Sir Mhkamran you are such a genius guy!!! Thanks for the help,i really really appreciated it ...More power and God bless you
NEED TO CHANGE FILTER IN COOLTEC 34700Z + NEED FILTER
There is a site www.nytechsupply.com you can down load a pdf manual free of charge. it will have the
instructions and any thing pertaing to your recycling machine. good luck!
Aug 03, 2011 | Robinair Cool Tech 34700Z Recovery,...
Machine will not read scale or does not weigh freon . will evacuate but will not charge says tank needs fill but will not fill either
Most robinair units require the filter to be changed every so many uses. If the filter is not been changed, the unit will not work.
Aug 14, 2010 | Robinair Cool Tech 34700Z Recovery,...
34788 COOL TECH,FILTER LOCK OUT,REPLACED FILTER TWICE STILL LOCKED OUT,READS FILTER ERROR
Check the filter monitor air flow differential switch is not blocked or broken. have you a manual reset after filter change?
Aug 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
My robinair recovery too low?
Check you machine filter capacity,If it is more then 68kg/150lbs then change spin-on filter as soon as possible. also you can check compressor suction line & ISV tank liquid hose for any lose connection.
Jun 11, 2010 | Robinair Cool Tech 34700Z Recovery,...
34700z resetting filter weight unit will not clear filter. it has a new compressor and vac pump
Check ISV tank liquid & vaipor hose.make sure it is not too much tight or lose. also check recovery,recycle & oil return solenoid are opening properly.
Jun 09, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robin air recovery station for R12, My Question is Can this machine be converted to recyled 134A, By changing the filters? Email to tdrworks@yahoo.com I thank you in advance. Sincerely Santos
Sorry you can not make this only with changing spin-on filter.because have to also change other things such as service coupler,ISV tank,manifold gauge etc.
May 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
I need to replace the filter in my Robinair 34700Z machine. Where is it located? And where can I find a manual to go with this machine? Mine is missing. . .right when I need it.
Press the main menu key,then upper arrow & go to "Change filter" option,then press "Yes" key & now follow on screen message(Do not skip any option while active ''change filter'' option).
For user manual you can try to robinair web official site www.robinair.com
Apr 20, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair 34700z not filling source tank / slow recovery
Please check the following:1# For not filling ISV tank (internal storage vassel) Check tank fill solenois,it's may need to rebuild or replace.2# For not compleet recovery,Check & make sure your machine compressor haveing 13''HG suction.if not then you have to replace new compressor.3# Check 13'' vacuum sensor is working properly.
NOTE:PLEASE CHECK FILTER CAPAICITY,BECAUSE EVERY 68Kg/150Lbs OF REFRIGERANT RECOVERY YOU MUST CHANGE SPIN-ON FILTER.
Jul 30, 2009 | Robinair Cool Tech 34700Z Recovery,...
HOW TO CHANGE FILTER just shows clearing filter please wiat
"Clearing filter please wait" if this message is running more then five minute then it's sound that your machine compressor is not haveing 13'' of suction ( Compressor is damage or weak suction) so you have to replace new compressor.Note:every 68 kg/150 lbs of recovering refrigerant you must change spin-on filter,otherwise you will have again same problem.
Jul 10, 2009 | Robinair Cool Tech 34700Z Recovery,...
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
680 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
