Question about HP Photosmart C8180 All-in-One InkJet Printer
4x6 photo paper won't feed into printer after I put paper in the tray it says to put glossy side down and I have done that. Do I need to clean a roller or something?
    Problem Solver:
  • 4 Answers
Click on "File" then click on "Print" in the dropdown
In the Print window click on "Paper/Quality" then change "Main Tray" to "Photo Tray"
Posted on Jul 15, 2011
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Paper jam
Unplug the printer from power for ten minutes.
Remove cartridges and put them back, open all doors and close them back.
Oct 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Trouble photo printing
hello.. try to unplug the power cord and usb cord and replug again and also chick the inside part of your printer maybe have a paper jump or ashes due to saying of of paper or try to remove the printer driver software how to remove? go to control panel and click the name (ad and remove program )and you can see the currently install files find your printer driver bellow the currently install files and remove it and install again..........thank you hope i can help you.. have a good day
Jul 06, 2009 | HP Photosmart C6280 Printer
C 4180 photo smart printer, not loading 4x6 photo paper
You could try stacking more paper behind it, thereby creating more pressure on the paper feed.
May 06, 2009 | HP Photosmart 4180 All-in-One Printer
Wont feed glossy photo paper
Clean the feed roller(s) with a cloth dampened with alcohol. They are probably slippery with paper dust.
Mar 17, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5280 doesn't print photo
my steven
u need to chek setting of pritner in pc when u do pritner command it's show pritner propaty this is capple of options like in cd pritner on photo 4x6 also give all setting u have to chek this setting it's help u
Jan 09, 2009 | HP Photosmart C5280 InkJet Printer
Kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Feb 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
HP Photosmart C8180 All-in-One InkJet Printer Logo
265 people viewed this question
Seeker5211
Seeker5211
