Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer not working when hooked up to notebook Installed printer to my laptop, but it says it is offline and won't print. I tried plugging printer into my laptop, still no luck. Printer is installed and working fine on my desktop computer.
  • 876 Answers
Try a clean install:
Turn off the printer and unplug it
Go to control panel and unistall printer
Turn off all your running programs including your virus control
(look in the lower right corner and click on each little icon there and turn off everything you can)
Now reinstall your printer. When it is finished, if it has not told you to reconnect your printer, do so now.
Restart your computer.
Good Luck. Please let me know if this works and rate my solution. Thank You.
Posted on Aug 18, 2008
SOURCE:
I am using LBP 2900b printer, my operating system is windows 10, but i am unable to take print offline. What is the solution?
I'm a bit confused...are you trying to print while printer is offline? Or are you trying to print and the the printer is offline and won't allow you to print?
If it is the second then check the printer to ensure it is properly plugged in and turned on. Also ensure that your computer has the drivers installed for the printer.
Aug 24, 2015 | Office Equipment & Supplies
Printers says it is offline
hi,
Being 'offline' means there is no communication between the printer and your PC.
To change it to 'online' try the following:
  • On the start menu,go to printers and faxes and check out installed printers.
  • Double click on your printer and a window pops up.On this window go to printer on the menu bar and uncheck 'use printer offline'. Try printing now.
  • Still offline?
  • Uninstall the printer[make sure you have installation disk]
  • Unplug the printer from power and your pc too.
  • Plug them back after a few minutes and start installation afresh.
  • After installation restart your pc.
  • Now print!
Worked for me,hope it works for you!
THANK YOU!
Sep 20, 2011 | HP Officejet 6500 Wireless All-in-One...
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Photosmardt c510 won t print messaging sayin it is offline
Assuming you are running a version of Microsoft Windows. Try going to Start -> Control Panel -> Printers Right click on your printer and make sure that "Use Printer Offline" is NOT checked.
Mar 23, 2011 | HP Computers & Internet
DOES ANYONE KNOWS HOW TO SOLVE MY PROBLEM?HERE IT IS..IT ALWAYS OFFLINE MY PRINTER EVERYTIME i print it,he goes offline and the print is unabale to print can anyone help me?to fix..thank you. im using HP...
when you hook up your printer to your pc via USB...can the computer detect your printer? does it prompt out any msg such as new device is installed and ready to use or did it ask you to install the printer driver?
if your pc can't detect your printer, replace the USB cable and try again.. and try to plug into a different USB port on your pc.. and if all fails, then most probably your printer main board is faulty...
May 28, 2010 | HP DeskJet F380 All-In-One Printer
DLINK DP-300U. Desktop shows printer offline, Laptop prints OK.
First thing.. plug printer directly into PC.. does it work? .. if so its is a port setting. If now it is the device config on PC
If Port Setting Issues.. are you going through any other devices on the network or is you firewall blocking the IP.
If device Config issue check to see it is setup up as an IP Port not a normal local port
Jul 15, 2009 | D-Link DP 300U (DP-300U) Print Server
Cannot print to network printer
Is this printer installed on a server and shared over a network? Or is it installed independently on each workstation?
If it's on a server, printing could be "paused", or set to "use offline" Go to the "printers and Faxes" dialog box, and 'right click" on the printer icon, is there an option to either "resume printing", or "use printer ON line"? If so, select this option.
If it's not on a server then it would be extremely unlikely that this condition would happen on all workstations
Other than that make sure that the Subnet mask is set correctly on the printer.
If that doesn't work....it's probably time to try re-installing the driver.
May 13, 2009 | Kyocera Copystar CS-1820 Black and White...
Photosmart 2575 printer is offline - won't print
In Vista make sure you are logged in as a administrator whenever you make any changes.
And if not to bring the printer online you will have to right click on the printer icon and right click on Run as administrator> and then try bringing the printer online and checdk if it works.
And you can delete the Microsoft XPS Document writer it is a default printer icon installed if in case you did not have a printer installed you can store them to print later.
Now that you already have a printer you can delete the Microsoft XPS Document writer.
Good Luck
Oct 02, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
