Question about Toshiba 62HM95 62" DLP HDTV
We put in a new lamp probably a month or so ago. I'm not sure how to describe it except that some colors are now "brighter" than they should be and flicker while watching TV. This seems to have come on gradually, but is getting worse. Thanks for your help!
  • Toshiba Master
  • 8,457 Answers
U replacing the tv with a new lamp with the original Toshiba reconmended lamp?Generic lamp might have this problems for some tv and don't last as long as the original name brand lamp.Also the board that call the Ballast board might be dying too.The Ballast board only job it is to ignite the tv projection lamp and kept it being lit.
Posted on Apr 07, 2011
Lamp replaced 1 year ago but tv is loosing contrast. Last lamp held up 2+ years. any other way to get a brighter picture?
Are you referring to a rear projector big screen? If so it's probably due for a coolant change in the lamps.
Jul 02, 2017 | Televison & Video
I own a Philips DLP television model 50pl9126d/37 I just replaced the lamp on it less than 6 months ago and the red lamp failure light came on. I have opened the back and can see the lamp starting up for...
You might want to with a flashlight and or small mirror want to look where the lamp faces at the color wheel---it must be intact and not missing any segments
typical color wheel:
12_3_2012_5_48_14_pm.jpgIf bad or not moving at correct speed set will turn lamp off quickly.
Dec 03, 2012 | Philips 50PL9126D/37B 50" DLP TV
Ony KDF- E42A10 lamp needs replaced, should I replace the fan also, just got a new lamp 8 months ago picture is dark
Usually the lamp gets brighter when it begins to fail. I would check to see how dirty the inside of the set is. There are beam splitters and lcd filters in that set and if they get dirty then you lose picture quality.
Nov 18, 2012 | Sony KDF-E42A10 42 in. LCD Television
TV has new lamp but no color
Tried putting the old lamp back?
Jun 14, 2012 | Sony KDF-37H1000
I have a Hitachi CP-S317 data projector that has been shutting off every 10-15 minutes. I replaced the lamp, cleaned the air filter, and reset both timers. When I power the projector on, it comes on, but...
It seems that the lamp ballast unit is not striking the lamp, or the new lamp is no good.
Try using the old lamp as a test to see if it comes on at all.
Apr 06, 2011 | Office Equipment & Supplies
Our picture seems very dark, We got a new lamp installed about 8 months ago and have played with the colors etc but after awhile the picture just goes darker. any sugestions?
There should be a setting for the dynamic contrast ratio(or backlite setting on some tvs). Turning the dynamic contrast ratio off should make the screen brighter. This is usually called the DCR setting, turn it to off.
Feb 28, 2011 | Televison & Video
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
Just moved into a house that has low voltage outdoor lights. They were working a month ago, but not sure what's happening now. Checked transformer. Lights work in the "on" position, but...
Hi GlennMayer1
The high pitched noise you here is the switchmode electronic type power supply/control electronics malfunctioning. This could be caused by component failure in the power supply or a short circuit in the wiring preventing it from firing up correctly. Hard wiring a lamp directly to the power supply would allow you to check the system, but a replacement power supply is probably required.
regards
robotek
Jul 15, 2008 | Universal Remote Control Hampton Bay...
Toshiba 62HM95 62" DLP HDTV Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
