Question about HP LaserJet 2820 Printer
HP Color Laserjet 2840
Printer seems to be printing fine but makes an awful grinding noise. Do you know what could be wrong?
    Problem Solver:
  • 7 Answers
You might find that it is the gear driving the fuser, these plastic gears get very worn when driving the ceramic fuser gear. Right Rear plate assembly RG5-7580 with the gears that connect the fuser motor to the fuser.
Posted on May 25, 2010
    Scholar:
  • 67 Answers
Need to order a replacement FUSER it's located in the rear of the printer. If you live in the USA you need 110V if you're in Euro 220V see below for the part number you need to order.
RG5-7602-000
RG5-7603-000
Fuser ***'y, 110V, CLJ 2820/2840
Fuser ***'y, 220V, CLJ 2820/2840
CLJ 2820/2840
Posted on Aug 06, 2008
SOURCE:
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Needing a users manual to trouble shoot printing issues
Hp has most of their user manuals online. Go to hp.com and you should find yours on the list. God bless.
Jan 13, 2009 | HP LaserJet 2840 Printer
HP Color LaserJet 2840 making awful noises
This can be numerous issues really.
Either the paper being used the printer does not like, this can be the texture, type, size etc try making sure all the rollers are clean. If problem persists Id take it to get a service done.
Good luck
Dec 03, 2008 | HP Color LaserJet 2600n Printer
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
"Rainbow" word art (Microsoft)
Have you tried prinitng this in MONO on your 2840 printer.
Does Wordart from Word or other office programs cause this?
If it is the office suite, then look at downloading some service packs from Microsoft.
If it's just your 2840 doing it, then look at downloading a different driver.
For some printers there are different types of PCL drivers, like PCL5 or PCL6, these do behave differently per printer, so swapping the driver might not be a bad idea.
Also check if you are using a PS or Postscript driver, but again, try the PCL alternative for your printer.
I would install the different driver under another name, for testing, then if it works just delete the bad one.
May 08, 2008 | HP Color LaserJet 2600n Printer
HP 2840 Colour Laserjet Printer Problem
Don't ever use compataable cartridge for printing .
(1)Check for printer sleave damage....
(2) check for any noise from printer when printing noise from fuser section.
(3).. Print a Demo color level page ...
(4)Check for scaner section ......
Thank you.
Feb 04, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 2820 Printer Logo
760 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
