Hi, the boiler was switched off by a tenant i had in my property, i swithced it back on - onto the domestic hot water setting, it fires up then quickly goes back off, i can briefly feel warm water before it goes stone cold again. can you help?
  • Roger Jelinek Apr 07, 2011
    It could be a number of different things. try resetting the thermostats on the boiler and tank first. Do you need to reset the boiler for it to fire again? Is the pump running? Thank you. Roger
  • 37 Answers
Oil boiler may need to clean filter nozzle and strainer
if gas need to change or clean the flam sensor rod
Posted on Dec 10, 2014
    Problem Solver:
  • 8 Answers
Your pump might be plugged with sediment. It will keep shutting your boiler down.
Posted on Apr 09, 2011
Model ALTHC014. Why doesn't the boiler switch off when the programmed temperature is reached?
Your boiler may have a domestic hot water coil inside it for domestic hot water, and the auquastat maintains a preset temp for that purpose.
Jul 24, 2015 | Heating & Cooling
My boiler dosent come on i have no hot water but when i turn the heating on boiler works but still no hot water what should i do
Hot water is gravity fed through your pipes. When you turn the faucet on the water will flow through the pipes. If your hot water heater is natural gas driven relight the pilot. Same if oil fueled. If electrical, check fuse to see if it has blown or the circuit breaker has tripped. If either has tripped, replace it and if it blows again the heater has a serious failure, you might need to buy a new one. If pilot won't light on gas unit, try relighting after 5 minutes, could be a bad thermocouple.
Apr 03, 2015 | Water Water Heaters
I have a Heatslave 12/14 oil-fired combi boiler installed approx 8 years ago. A problem has just developed on the domestic hot water side. My local heating engineer has investigated but so far hasn't...
Symptoms sound like crossover might be part of problem:
Crossover is when cold water enters hot water line due to faulty plumbing part like check valve, mixing valve, or bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
Jun 12, 2011 | Bosch Water Heaters
Does the boiler thermostat control the heat of the radiators as well as the hot water temperature? Does the thermostat control the water temperature and the pump - as our pump seems to be on all the...
There should be a control called an aquastat that regulates the temperature of the boiler. The thermostat will turn on the circulator to start the flow of water through the radiators. If the water coming back from the radiators is very cold, a control will shut off the circulator until the boiler can come up to a predetermined temperature then start the flow of water again. If you have a tankless coil for domestic hot water, you now have a triple aquastat that maintains the temperature for domestic as well as the boiler temp. So yes the boiler thermostat (aquastat) does control the heat of the radiators and domestic hot water. No the pump is regulated by your house thermostat. You should take an amp draw on the boiler and componants to find out what is drawing more electricity than it should and popping your fuse.
Feb 19, 2011 | Heating & Cooling
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Central heating system boiling
more information required but if the boiler supplies the domestic hot water cylinder then the stat on the cylinder may be bringing on the boiler also the boiler stat may be up too high try turning it down.
Jan 05, 2009 | Heating & Cooling
Vaillant Ecotec combi boiler - radiators working but no hot water flow to taps
David,
The fact that you're getting a little burst of domestic hot water suggests that the boiler is capable of circulating hot primary loop water through the heat exchanger, but doesn't necessarily do so when it needs to.
What seems to be lacking is a recognition that domestic hot water is now being drawn off, and that the boiler needs to fire up and divert the primary flow through the heat exchanger.
A good place to start might be the flow switch (usually in the bottom of the boiler, where the cold water supply comes in) or the electrical connections to it.
A.
Oct 05, 2008 | Heating & Cooling
Have an oil fired boiler for baseboard heat and it also has a tankless heater for domestic hot water. No heat being called for only getting hot water for use. Boiler goes to 210 degrees before it knocks...
These boilers usually have multiple controls. The control that would take it out of the circuit at 210 degrees is a safety.
You should definitely have a professional take a look at this unit before you continue using it.
Sep 18, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
