Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor problem width problem. Screen cuts short from both the sides.
  • Anonymous Apr 03, 2009
    hi
    i hv a problem with my desktop .........
    aftre giving power ..its on for 1-2 min but den its off.........
    wat should i do ..........wat is d problem inside?
    Brigadier General:
  • 6,966 Answers
Appreciate the "Ask Me".
I am assuming that you have more than just familiarity with electronic components and circuitry, the use of a DVM and a soldering iron. Further, that you have access to a service manual.
Width problem is basically insufficient horizontal deflection, then analysis would have to be in the horizontal section. Areas to initially focus on:
  1. 12V line and pin 29 of IC401;
  2. 110 V peak to peak at collector of Q403, if yes check Q 402 & 404 as well as T401;
  3. other components that affect the horizontal size are:
  • IC201
  • Q 405, 406, 407 & 408;
  • D409
  • L401
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
Intermittent horizontal sync out No power Intermittent colors problem Missing red color (only cyan color) Missing blue color (only yellow color) Horizontal sync out (Display rolling horizontal) Vertical sync out (Display rolling vertically) Contrast dim, Brightness o.k Display becomes blur after sometimes No power Power blink Horizontal Output Transistor always burned when switch on One horizontal line Adjust brightness No effect Adjust brightness No effect
Posted on Aug 20, 2008
  • 20 Answers
The problem lies with some points on the circuitry which have came off the circuit board. Solder it after replacing with a spare similar to the original.
Posted on Jul 18, 2009
I have 17 " zenith monitor ,my image is flickiring ,when i adjust data cable the image gets clear please solve the problem
shekhar
Posted on Jul 04, 2009
    Problem Solver:
  • 18 Answers
Obviously you have a problem with the horizontal deflection circuit. try replacing those 10uF capacitors on the horizontal circuit. Look it up on the schematic diagram if you have one.
Posted on Oct 02, 2008
My monitor not powering on
i need circuit diagram for this monitor 753s
Posted on Sep 12, 2008
3 Suggested Answers
mail2pvs
  • 390 Answers
SOURCE: Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Posted on Jun 29, 2009
  • 7 Answers
SOURCE: width is short
You will need to 'Auto Adjust' your sreen
Posted on Jul 16, 2009
What is cost of yoke for panasonic ct tv?
You're discussing about the width problem to picture. If yoke have a short in between its wingdings [even a single winding short], will cause the failure of horizontal output transistor. As per you report here, the set has a raster, but problem is with the picture width.
There possibliliites for this fault are.
1. Lack of voltage from the SMPS power supply output.
2. Horizontal width capacitor.
3. Horizontal output capacitor.
Check the output voltage from the SMPS section first, and confirm that it is OK.
Jan 03, 2013 | Panasonic CT-24SL13 24" TV
Width problem
A width issue specially if this is short of width on the screen can be due to many reasons:1. It can be a low +B which means the SMPS power supply has a lower output due to low Switching or a low value on the main capacitor. Check this out, measure the +B on the mains end and also the secondary side which will confirm.2. If the secondary +B is correct the fault can be with the sync circuit IC or the horizontal coil or even a fault with the deflection coil. A proper measurement of the voltage in this section is important.3. Check for weak capacitors and DRY soldering on the horizontal section , line output section.
Dec 15, 2011 | LG Studioworks 700S 17" CRT Monitor
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
Width is short
Jul 16, 2009 | Computers & Internet
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Monitor width is out of screen
Check for shorted transistor, shorted diode, leaking/dried capacitor it could be ceramic or electrolytic. Look for some shunting diode or capacitor that is connected about horizontal size/width ciircuit. Leaking, shorted or open can make horizontal size shrink or expand.
Apr 11, 2009 | Compaq Computers & Internet
Samsung SyncMaster 753S 17" CRT Monitor Logo
1,180 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
