Question about HEALTHRIDER R65 Treadmill
My treadmillmotor will turn on with the key,but will not change or run aprogram or will not shut off unless or reset unless i remove the key.
    Problem Solver:
  • 14 Answers
Replace your upper electronics board and touch pad. It is no longer reponding.
Posted on Apr 09, 2011
Changed battery terminals and now dinging wont stop unless warning light fuse removed
It sounds like it thinks the key is still in it all the time. Try turning the key forward to the on position, but not running, so the dinging stops. disconnect the battery. Remove the key completely and reconnect the battery.
Oct 21, 2014 | 2005 Dodge Caravan
How do you reset the anti theft system in a Chrysler 200?
try to reset by removing the bttery negative with the key on..then shut the key off and reconnect the batery negative..turn the key to the run position and let reset the computer.. see if that works..
Jan 21, 2013 | Chrysler Cars & Trucks
Why does my 2005 chevrolet classic theft system keep coming on and then the car won't start afterwards unless reset by turning the key to ACC for 10 minutes then the car starts?
If you have a spare set of keys try using the different key. The identity chip in your key may be shorting.
Otherwise the "Reader" in your ignition switch may be cutting out. This puts it into an activation loop.
Nov 08, 2012 | Cars & Trucks
2002 f350 will not shut off with key. with key removed dash lights stay on and engine continues to run must pull injector relay to shut down. the dash lights stay on as if you turned the key to accesory...
ok well this is where you might be incorrect... either you have a 12 volt wire bleeding scross or you have a bad ignition switch. the run wire off the ignition switch is the only thing that will keep it running unless you have a remote start then of course that could keep the engine running. you might want to start by making sure the ignition switch is beaking the signal to the PCM.
Aug 27, 2011 | 2000 Ford F350 Super Duty Super Cab
Electricity is not reaching fuel pump. Wiring is fine. 1990 F350 4.9 Emgine Automatic transmission
the power relay activates the PCM, engine computer. The PCM activates the fuel pump relay that turns on the fuel pump with key ON. It runs for 5 seconds, then it shuts off, unless the engine starts. Can you hear the pump run (hum) in th fuel tank when key is turned ON?
Also, reset the inertia switch in case it tripped. Owner's manual will tell you where it is. Rest is pressing the buton.
Jul 29, 2011 | 1990 Ford F350
Why wont my 96 chevy cheyenne 5.7 run unless i put
Probally needs fuel pump. Pump is in the tank. remove gas cap listen when you first turn on key it will run for a few seconds.
Sep 25, 2009 | 1996 Chevrolet Crew Cab
How do you reset the change oil light on a 99 grand am 2.4?
hi to reset the oil life remove the fuse pannel door on the drivers side of the dash and check to see if there is a RED button with RESET on it turn the key to run push the RESET button and watch the change oil light if it flashes then press and hold it till it goes out If it dosent have a RESET button turn the key to RUN ENGINE OFF pump the gas pedal 3 times with in 5sec the light will flash then go out
Jun 16, 2009 | 1998 Pontiac Grand Am
94 isuzu trooper turn key fuel pump runs for 2sec.and shuts off?
Can you hear a click during that 2 secounds? Thats the relay shutting off the pump just what its suppost to do. The pump does not run contenuosly, if it did it would burn up, thats what the relay is for, it kicks on and off to maintain the correct pressure to engine as needed. It will not turn back on until it resets itself because engine was not running, thats the way there designed.
Feb 19, 2009 | 1994 Isuzu Trooper
Won't boot into new screen
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Hold down [Home] [Enter] [P], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
    1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts. 2. Delete Operating System – The operating system will be deleted without deleting any documents. 3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS. 4. Complete Format – This will delete the OS and all documents for a total erase of memory.
    Note: TI-Nspire family model options 2 and 4 above require that the OS be reinstalled. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
Nov 22, 2008 | Texas Instruments TI-Nspire Graphic...
HEALTHRIDER R65 Treadmill Logo
504 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
