Question about Hotpoint Dryers
Drum moving slowly and over heating - Hotpoint Dryers
  • 413 Answers
Sounds like you need a new belt
Posted on Apr 08, 2011
The drum is not moving properly. It starts to move slowly and then grinds to a halt as if it is being obstructed.
Not knowing the model you are working on but it sounds like you have an obstruction between the inner and outer tubs
Feb 18, 2016 | Washing Machines
Something catching on drum
is it noisy in the spin cycle?on the back wall of the drum it looks like a peace sign,this is where the spider gear and or rear bearing is,the gear can crack from overloading or using to much detergent,this could be what you're hearing as you move the drum,if it's something between the tub it will end up in the pump but most likely it's from the spider gear,i've seen this before,when it starts to pin fast gravity pins the broken part to the side but when you move the drum by hand you can hear it,use it and keep an eye on it,if your washer starts getting loud in the spin you'll know it's the spider gear,it would cost more to fix it than have it repaired so this means new washer time.
May 18, 2014 | Kenmore HE2 Plus Front Load Washer
Clothes are being shredded in washer
it sounds like you have a bent piece of metal round the drum you will have to make sure the drum is empty with your hand very slowly move it round the whole drum if you find it with a small hammer don't hit it heard OK just tap it till its not going to shred your cloths OK if you don't find any thing you will need to look at the paddle in the drum to make sure there not Brock or moving OK hope i can help
Oct 22, 2012 | Maytag Washing Machines
Frigidare ftw 647ghso thumping sound in one spot when i manually rotate drum sounds like its rubbing on something
Suspect a bad drum bearing or bent drum bearing shaft. When you rotate the drum, look for movement of the drum up or down while turning. If the drum moves suddenly, suspect the drum bearing. If it slowly moves up or down during turning, suspect a bent shaft on the drum. In either case, it is a major teardown to remove the drum from the outer drum case. If still under warranty, take advantage! Hope this helps!
Mar 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Replace belt
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Maytag MDG3000AWW drum moving slowly
If the belt looks worn you should replace it. But it sounds like the idler pulley has gone out of position or possibly broken. The idler pulley adds tension to the belt and keeps it from spinning on the drum surface. Check the path of the belt on the bottom of the dryer. That is where the idler pulley is.
Feb 01, 2008 | Dryers
Washer will not spin or drain water
I have a roper washing machine model RAB 2121kw and about a year ago it did the same. I was at the machine when it tried to spin one day and i opened the lid and spun the drum by hand a few times then shut the lid and slowly the drum started spinning. One problem is that i have just moved the washer and i now have an oil leak. When the drum wouldn't spin i think the motor heated the oil seal on the gear case and now it leaks. I have looked into it and don't think its that hard of a thing to change.
May 24, 2007 | Roper RAB2121KW Top Load Washer
No Color
did u try cleaning the video head? heres how! unplugged the unit. open the cover. get a piece of clean white paper. put a little alcohol on it. place your finger on the paper and slowly touch the head but not too much force then gadually move the drum back and forth. donot move your finger up or down. just clean it horizontally by slowly moving the drum leaving your finger stationary. let it dry and test. if the problem persist see a doctor(technician), u have a problem with the color circuits. good luck!
Jan 31, 2007 | Aiwa HV-MX1 VHS VCR
Dryers Logo
32 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
