Water in ok, program clicking ok .,water drain ok.,belt ok.,no drum action or motor movement at all. 7 years ago similar problem, module AO64585 replaced under warranty then ok. Could be the same problem again ?Help please! Regards Wally.
  • 6 more comments
  • wjanczewski Apr 07, 2011
    Sorry I don't know what I have to do? I thought I supplied Model No. If not : Ariston AB936TAUS. Regards Wally
  • wjanczewski Apr 08, 2011
    "The motor needs replacement and testing it won't help," - This part is not clear to me ? Maybe some wording is missing? Do you know cost of a new motor? Regards Wally.
    Ok, as far as I undrestand it's a motor, is it correct? Tomorrow I test with a meter for power supply. Thanks for a link to spare parts,but i live i Australia and here is much cheaper then UK. Regards Wally.
  • wjanczewski Apr 09, 2011
    Thanks, this is clear! Do you think motor rewind will do the trick ? What about brushes ? Regards Wally
  • wjanczewski Apr 10, 2011
    What about motor rewind ?
    Thanks Kevin,that's all what I wanted to know ! Regards Wally
  • wjanczewski Apr 11, 2011
    Thanks,You have been very helpfull. Motor cost in Aus.$455 !! Not worth it , rewind is only option if is cheap if not I buy new machine .Regards Wally.
    Thank you I'm very happy with Kevin response . Good clear answers great help .Now I know where I stand .Regards Wally
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
The motor needs replacement and testing it won't help, but if you want you can test it for 120vac while its unplugged. The control module seems to be fine as everything else is fine. Please get back to me if you have any other questions.
Kevin
Posted on Apr 07, 2011
  • 3 more comments
  • Kevin White
    Kevin White Apr 08, 2011
    Yes the motor needs replacement....get back to me for any other questions.
  • Kevin White
    Kevin White Apr 09, 2011
    Yes right motor needs replacement
  • Kevin White
    Replacing the brushes wont work
  • Kevin White
    Kevin White Apr 10, 2011
    You can do it but getting a new one is best thing
  • Kevin White
    Thanks....you can give this solution helpful rating if its solved for you
    President:
  • 1,654 Answers
Most likely the answer is yes. If not the module then your motor could have gone bad. Do you have a volt ohm meter to test continuity on the motor or if power is getting to the motor. This needs to bhe done to rule out a bad motor.,
Posted on Apr 08, 2011
  • Dcramer531
    Dcramer531 Apr 08, 2011
    A replacement motor, depending on the motor, there are 2 I believe run around L100.00. they can be found here or a local parts supplier may be able to match one up and save a few dollers.
    shop.ukwhitegoods.co.uk/Washing+Machine+Parts/Ariston.htm
  • Dcramer531
    We will know after you test it if there is voltage at the motor, then the motor is bad, if not then the control module is suspect. If you know anyone who rebuilds motors they can rewind yours for a fraction of the cost of new also.
    Guru:
  • 262 Answers
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
BEKO WM5120W filling with water program clicking water draining but the drum does not turn belt is ok and pump
DOES IT AGITATE? SOUNDS LIKE A BAD MOTOR COUPLER OR DOOR SWITCH, ALSO A BAD WATER PRESSURE SWITCH WILL NOT ALLOW IT TO GO INTO WASH, HENCE NO SPIN OR WASH CYCLE? SOME MACHINES HAVE A BELT SAFTY SWITCH ON THE MOTOR, THAT MAY GO BAD AT TIMES ALSO AND SHUTS OFF ALL ACTIVITY
Sep 26, 2014 | Washing Machines
Wont spin or drain
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jan 24, 2013 | Washing Machines
Zanussi jetsystem ZJD-12191 TURBODRY washer dryer drum will not turn
Jan 22, 2013 | Washing Machines
Drum will not work and err 7 comes up
Dec 11, 2012 | Washing Machines
SPLENDIDE WASHER PROBLEM
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Mar 14, 2012 | Washing Machines
Put wash on, no water have checked water supply all ok ?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. In this case the inlet valve is not working and allowing water to flow . Check the voltage on the inlet valve, if absent then the program controller unit if faulty. If not the inlet valve must be checked
Thank you for using fixya.
Sep 21, 2011 | Zanussi Washing Machines
ZANUSSI FLS 1383 washing - cycle starts with water loading for 5 secs then it freezes there, no drum rotation.Tried spin cycle but again the drum does not rotate. Belt ok. Any suggestions?
Sep 17, 2011 | Zanussi Washing Machines
Machine fills with water and does not agitate,however i can hear the motor humming
It seems that the belt has come loose and so you will need to replace the belt.
Please look into the machine and check the belt or the drive for the fault.
Check this link for a visual :
http://www.espares.co.uk/advice/washing-machines/a/7/1375/how-to-replace-the-belt-on-a-washing-machine-.html
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Aug 03, 2011 | Kenmore 22422 Top Load Washer
Wont spin and makes alot of noise
You could check if its drum by removing the belt turn drum by hand if its okay no noise check motor pulley ....is motor ok ?
Nov 17, 2009 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
