Question about Foxconn G31MX-K socket LGA775 motherboard
No display on my motherboard and cpu fan not on smps is ok
  • Foxconn Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 07, 2011
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
All the components are working properly but i am not getting anyh display on my monitor i replaced every thing and checked my monitor is working ram is working cpu fan is working power supply is ok smps is...
1- evolve the battery.
2- install it again but upside down.
3- turn on the PC.
4- wait 15 seconds.
5- turn the PC off.
6- install the battery correctly and enjoy. please rate.
Jan 17, 2011 | Mercury P4VM800M7 Motherboard
No display when power on, only cpu fan runing,smps,ram, also ok.but no display .
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 09, 2010 | Intel D845GVSR Motherboard
Mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
May 30, 2010 | Mercury P4VM800M7 Motherboard
No Beep sound during startup. Motherboard or Processor ?
ok
pull cmos cell for 15 minute then check so all settings of bios are reset.
Also Refix RAM memory reattach all connection to motherbord.
Jul 16, 2009 | Asrock P4I45GV R5 Motherboard
Cpu fan ok no display
Hi
maybe the processor is defective try to replace a new one
thanks!
Jul 08, 2009 | Intel DG31PR Motherboard
No display for the Motherboard D945GCNL
how to solve asus motherboard blackout
Mar 22, 2009 | Intel BOXD915PCYL Motherboard
AsRock Motherboard won't boot. Need Advice.
Here's the solution!
Check if NUM lock glows if tapped on the Keyboard ::
Yes - If your Power LED is blinking change the SMPS, if it is Solid, change the I/O cables or RAM or Display Adaptr - whichever you think the problem to be.
N0 - Change the board.
PS. If processor is the problem, CPU fans won't spin in the first place.
Jan 10, 2009 | Computers & Internet
Cpu not starting up....power 2 cpu from smps is ok..
hi most of motherboard power on pin is 6 and 8 just short these two pins once if mothernoard starts it;s giving display else check ram or smps otherwise motherboard faulty.
Oct 03, 2008 | Intel Motherboard
Monitor
Reset the Cmos battery,check the RAM,check the smps or check the motherboard ground, I think you problem will solve.
Feb 16, 2008 | Computers & Internet
Foxconn G31MX-K socket LGA775 motherboard Logo
102 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
