Question about Amana Washing Machines
Amana 7300 Tandem front loading washer will not cycle through a normal wash cycle. The cold water will work but nothing elso and only in a rinse cycle. The washer keeps beeping and the wash light flashes.
5 Suggested Answers
BIKER T
  • 909 Answers
SOURCE: washer keeps beeping
HATE TO SAY IT BUT THE BOARD WOULD NEED REPLACEMENT.BEEPING NORMALLY INDICATES A FAULT CONDITION WHICH WOULD STOP THE CYCLE(WASH) OR THE COMPLETION OF A CYCLE.
Posted on Jul 19, 2007
dh1200s
  • 335 Answers
SOURCE: maytag neptune washer keeps beeping
The Service Manual for reference. Sears Parts Direct for reference.
I have tried to work with a few folks on this issue never received feed back to resolution see this post. I feel the issue is caused by one of three possible issues.
A stuck key issue/defective Spin Cycle key making constant contact forcing the Key/LED to cycle thru the Spin Cycle settings. Under normal conditions if you press and hold the Spin Select key it will cycle thru the settings, yours has a mind of its own (defective issue).
A false signal from the Control Board for the Spin Cycle.
A corrosion path issue at the Membrane Pad ribbon cable socket connection between pins 5 and 4. See page 20 of the SM button functionality “Spin” key.
Try to verify that the spin cycle membrane key is not stuck/defective signaling the Control Board to cycle thru the spin settings. I have not experienced this issue but let’s try the Membrane Pad Test
to get a start point. See the Service Manual page 15, I have modified the process to make it a bit more understandable at least for me. Make sure the two digit display is not On or Lite.
Press the off button first so there is nothing displayed in the Two Digit display of your FAV6800AW.
Now Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys for three seconds or until the control beeps. While in Service Mode, pressing the Presoak key will start a membrane switch check that verifies switch operation.
All the LEDs (except Presoak ) can be toggled or slewed by pressing the key associated with the LED or set of LEDs. Do not press the Presoak again during this test.
Press each key once and only once including the Signal Key the on side and the off side, also the UP and Down Arrow key of the LED display. All keys (including the OFF button) must be pressed within 5 minutes for this test to pass. “PA” will be displayed for five (5) seconds once all keys have been pressed and the test is completed (more like PA will be displayed for only a few seconds on my FAV6800AW). Following 10 seconds of inactivity at any point, this test will exit without any display. Let us know the results.
See my additional comment this board has message limit issues.
Posted on Sep 17, 2009
richroth
  • 9472 Answers
SOURCE: amana tandem 7300 stopped ,door is locked wash
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Posted on Nov 28, 2010
caroldon
  • 17130 Answers
SOURCE: I have a Amana tandem 7300 it starts beeping and stops working
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Dec 11, 2012
I have a Amana tandem 7300 front loader washing machine. It's stopped working nothing's happening except the display lights. Stopped in the middle of the wash cycle is there a reset button? Offbalanc
The only reset is to unplug the machine from power for about 5 min's and if that fails you may need to replace the washer timer control board.
Apr 19, 2017 | Amana Washing Machines
Why is my Amanda 7300 tandem washing machine not doing the wash cycle? It stops after water has filled and stats to beep 3 times in intervals....
Sometimes this can happen when the power button does not return completely when pressed in. My cheap & cheerful solution was to use a bit of Blu-Tak on the button, so I could pull it all the way out.
Sep 23, 2016 | Amana Tandem 7300 Washer and Dryer Stack...
My amana tandem 7300 will not turn on any cycle it will go back to wash but does not turn on it just beeps please help if u can
It may think the door is open, front load machines will not proceed to fill if they cannot sense a locked door...
Apr 22, 2016 | Amana Washing Machines
Washer cycling on it's own...filling and forcing door open...sunami
Mine was doing the same thing. The solenoid is out and is letting water push by the valve in it. The solenoid is where the hot and cold water hoses hook up on the back of the washer. The part is super cheap and is very easy to replace. There are tons of videos on youtube. I used this video. Water Inlet Valve Replacement part 8182862 Duet HE3 Washer Repair
Apr 10, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
Water runs out of soap box during rinse cycle
Hi there, given this a lot of thought. I had same problem. Could be that you are in a hard water area. Soap is not dissolving properly and building up in the rubber tube between soap box and drum. How I resolved this. Turn off power remove top cover of washing machine and massage the rubber pipe between soap box and drum to soften and cause undissolved saoa to drop into drum. This should rectify problem. Also consider using every month some descaler powder called Descaler cheapest from Axxxxn best wishes.
Feb 26, 2014 | Amana Tandem 7300 Washer and Dryer Stack...
I HAVE AN AMANA TANDEM 7300 IT STARTS THEN STOPS AND BEGINS BEEPING DOOR WONT UNLOCK TO GET MY CLOTHES OUT WHAT DO I DO???
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 24, 2013 | Amana Tandem 7300 Washer and Dryer Stack...
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
939 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
