Question about Dyson Ball DC24 Bagless Upright Vacuum
Needs repair, does not have any suction, have been unable to use for months. where can I take for repair please.
  • Official Brand Answer
  • 2,572 Answers
You should be able to restore full suction to your DC24 without the need for further service by following these simple steps: http://www.dyson.co.uk/support/help.asp?article=1943&product=DC24-ALLFLOORS
However, if you're still having difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run though some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 09, 2011
No suction motor comes on at all
It should be under warranty. Take it to a warranty repair center
Jan 17, 2014 | Kenmore 31913 Progressive Direct Drive...
Miele 5281 vacuum cleaner permanently on high speed
Most likely the speed control board has failed. The solution for this is to replace the electronic unit unless you know of someone who can diagnose and repair circuit boards. The part is common and easily replaced for around $60. Miele's website can point you in the right direction for a service center, or tell me your zip code and I'll look it up for you.
Nov 09, 2013 | Miele Vacuums
My Electrolux Precision Brushroll Clean Bagless Upright Vacuum, EL8807A Won't Start. I Plug it in and turn it on and nothing ... no motor sound no suction, it has a burn smell. The brush will roll but the...
The burn smell means you should take it to a qualified Electrolux repair facility. It may be an electrical issue and could catch on fire if not repaired properly.
Oct 25, 2013 | Electrolux Vacuums
My Hoover steam vac spin scrub will not suction up the cleaning solution . Why is there no suction?
p{margin-top:0px; margin-bottom:0px;} Hello,
Thank you for your recent e-mail. I am sorry to read about the problem that you are having with your cleaner.
Please make sure your recovery tank and lid are installed correctly and forming proper seals. Make sure that your filter is clean of any debris. Clean the screen in the tank lid. Make sure your nozzle and squeegee (if on your model) are free of dirt/lint/hair and attached in their holsters correctly. Make sure you do not have any clogs in the hose.
To restore suction, please try the following:
*Remove dirty water tank and clean filters- main reason for low suction is dirty filter
*Verify the dirty water tank cap is not missing.
*Verify dirty water tank lid is inserted completely into unit.
*When cleaning, the yellow float inside of dirty water tank should be free moving.
• First remove your clean water tank and unplug the machine
• Remove the dirty water tank lid and push the front panel piece (square plastic sliding piece in the front of tank) down to make sure it is inserted all the way.
• When reattaching the lid, hook the tabs on the front of the lid to the tank first, then click shut in the back. Pull up on the lid firmly, it should not lift at all. If it does, try reattaching as a seal needs to be formed for suction.
• Test to see if suction has been regained.
If these suggestions do not solve your issue please call a service center.
Your cleaner has at least a 6 month warranty for manufacturing defects. This warranty begins from the date of purchase, with the original sales receipt. If you do not have the original sales receipt, the warranty may be verified at the warranty repair center by MFG or serial number.
Please visit www.Hoover.com and click on service center locator for a list of authorized dealers in your area for service and warranty assistance.
Sincerely,
Hoover Customer Service 62
1-800-944-9200
Mon - Fri 8am to 7pm EST
**Please do not reply to this email address. This is for outgoing messages only.**
servlet.imageserver?oid=00da0000000yf5q&esid=018g0000005bxv6
ref:_00DA0Yf5Q._500G0AodT5:ref
Aug 08, 2012 | Hoover SteamVac F5914-900 SpinScrub...
My Dyson animal seems to have an electrical issue that I am unable to pinpoint. Neither the wand nor the floor vac have any suction AT ALL. In fact the vac makes absolutely no sound and you wouldn't even...
there is a filter inside the canister, and by your description it sounds like it needs to be cleaned. if you remove the filter and blow it out using a air compressor or using a slightly ridged brush and tapping the filter out this should solve your suction issue.
c...
Jan 02, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction to the canister
Sounds like you have a blockage somewhere. I would take the hose off the canister and test for good suction. if ok then you have an issue with the hose and wand assembly. follow this to determine where you lose suction.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 20, 2009 | Vacuums
Suction problem
first thing you need to do is replace the disc filter benieth the conical shaped shroud. also there is batting in the upper part of the vacuum tat should be replaced once every 4 years as well as it gets clogged with carbonfrom the motor. this increases the air flow through the vacuum keeping the motor cool and increasing your suction as well. the disc filter benieth the conical shroud should be replaced every 6 months under normal use and every 3 months under really dusty situations, and if vacuuming up fine talk powder every month. also check for a clog in the hose by hooking the hose up to the blower port on the top of the vacuum.
Sep 15, 2008 | Filter Queen Majestic Canister Vacuum
No suction on Hoover Wind Tunnel.
Greetings from GoVacuum.com,
First this is a common problem on ALL bagless vacuum cleaners. Usually it takes longer then 1 day however.
Is there no suction in the suction hose, or is it not suctioning from the floor?
Most people buy a bagless vacuum once, then return to a bagged one after their bad experience, you are not alone!
Please give me the model number to your Hoover, (found on the bottom or the back of the vacuum on a foil label).
Thanks,
Chris Jones
GoVacuum.com
1-866-468-2288
chris.jones@govacuum.com
Aug 18, 2008 | Vacuums
Not working
If only 2 months old, take it for repair as it is under warranty.
Mar 28, 2008 | Dyson DC18 all floors Bagless Upright...
Dyson Ball DC24 Bagless Upright Vacuum Logo
1,492 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
