Question about Microwave Ovens
I have a samsung over the range microwave serial number SMH7185TG that was installed in another house took out and put in another house was not dropped or damamged in any way when installled turned the light on then the turbo fan power went completly off removed bench test checked all connections and fuses loose dieods etc.powered back when you turn mic on with turbo fan starts making sounds like arking out or metal in mic then it persisted to doing it when you turn the mic on even with out turbo fan takes five to ten seconds before noise begins
MicrowaveSvc
  • 9047 Answers
SOURCE: Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Posted on Dec 14, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: NN-T990SA Panasonic Microwave Stopped Heating
This model uses an inverter to produce high voltage instead of a convential transformer system. While an inverter (switched-mode power supply) is more efficient from a power consumption standpoint, it is more complex, thus more statistically prone to fail. These should only be examined and worked on by someone who has the necessary technical qualifications. Seriously. Often the machine-soldered connections in a microwave inverter are too weak, so they eventually fail, especially if heat is high in the area. They sometimes fail catastrophically. When not catastrophically damaged, you may hear clicking or squealing and may smell an electrical odor, which is sometimes obscured by the cooling fan. Some manufacturers do not encourage or assist technicians to repair microwave inverters. Most offer the inverter as a whole assembly. But sometimes that is actually cheaper than the time and labor required to fix the old one. If a technician is willing and able to troubleshoot and repair the inverter to component level, it will may be expensive, but may be worth it, especially if he or she will resolder and reinforce connections as needed as part of a thorough repair. That could easily make your inverter beter than a new one! You might be able to get some verbal estimates if you call Panasonic-authorized repair shops and ask then specifically about inverter repair and inverter replacement costs for your model number.
Posted on Dec 23, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Sparking / Popping Microwave
GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touhc with a local authorized servicer.
Posted on Apr 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: buzz, plastic smell and no heat
Chances are you have a magnetron that's failing. GE had a rash of "underperforming" magnetrons on these units. They replace the magnetron, stirrer and high-voltage diode at no charge for parts as long as a GE-authorized service center does the work. Sometimes the unit gets run too long in a failing state and the waveguide and chassis of the oven get damaged. The bulletin shows you where tyo check. To see if yours is covered, see this bulletin: http://www.microwavedisplay.com/ge_mw_mag_kit_bulletin.pdf Otherwise, you need to contact GE Customer Relations at 1-800-386-1215 as soon as possible and tell them your problem and they will put you in touch with a local authorized servicer.
Posted on Apr 11, 2007
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
Posted on Apr 01, 2008
I cannot find where to put the charcoal filter, please help. My overhead range microwave is a Samsung
We would need your model number form the tag in the cooking cavity, etc. to be able to help you.
William Edward Miller
pupista@gmail.com
microwavecontrol.com
Aug 12, 2016 | Samsung Microwave Ovens
Keypad replacement
Remove the front housing and diconnect the ribbon cable very slow.look to see how the key pad was installed and remove it and install the new one. it's not very hard just watch what you are doing and don't lose any small screws
Mar 19, 2014 | Samsung 30" 1.6 cu. ft. Over-the-Range...
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Where do i find the serial number for this range
If there is no label on your microwave's inner wall, consider searching online within the manufacturer's website. Model and serial numbers can be found at the rear of most microwave ovens.
Hope helps.
Jul 07, 2011 | Microwave Ovens
I have a microwave range vent and I need the installation instructions for it.
Hi. These unit were made by Samsung exclusively for "The Brick" In Canada They have their own model numbers other than the usual Samsung model numbers. I did my best to try via samsung global but no joy. The best I can tell you is to call them and ask for the manual: (have your BMHC815SS model number ready.)
1.877.843.2742
Thanks for choosing FixYa.
Kelly
Sep 16, 2010 | Microwave Ovens
We have an old microwave that we took off our wall and want to install in another house but don't remember house to hook it on plate attached to wall
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and mention that you want the installation instructions.
Nov 24, 2009 | Amana MVH220E Microwave Oven
I need install instruc. for a Whirlpool wallmount microwave.
sears should be able to get you the installation instructions and maint manual for this also, get on line go to sears.com and look up uour microwave part number like you did and look for the manuals
Dec 08, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave installation
You can download Samsung over the range microwave installation instructions here.
Your model may vary, but these are all that are available.
We have the owner's manual, and you can download it from our site.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
